| » wire replacement |
Model Number: gss25jetacc Brand: GE Age: 5 - 10 years
had repair man at house to repair fan in freezer said the power wire to fan had a short in it inside the cabnet said unrepairable cannot except this seeing how its only low voltage wire 13.5 volts need schamatic so i can replace wire can you help?
Look for the schematic behind the encoder in the fridg section. Probably will not help. If you can confirm a bad wire to the motherboard, you can route a new wire inside the drain hose. Have done this before.
__________________
| Display Modes | |
| Wire Harness Replacement | Boilerserviceman | Refrigerator & Freezer Repair | 0 | 02-04-2012 09:00 AM |
| Wire Harness Replacement | Boilerserviceman | Refrigerator & Freezer Repair | 0 | 01-15-2012 03:14 PM |
| Wire colors on replacement motor don't match | liwarren | Trash Compactor Repair | 0 | 05-05-2011 07:29 AM |
| ground wire replacement on washer | primetime22 | Washer Repair | 1 | 11-12-2009 04:56 PM |
| Boot wire/spring replacement | ChristieB | Washer Repair | 1 | 08-30-2009 01:38 PM |
