Water Valve Assembly
Model Number: TFX28PPCBWW Brand: GE Age: More than 10 years
I am replacing a GE Refrigerator's Water Valve Assembly. The original part was a part # WR49X10043 assembly but as it has been replaced with a new assembly part # WR57X10084. I ordered the assembly conversion kit and the instructions are clear on the water line connections. But...as part of the assembly kit the new wiring was not attached to the selonoid connections and I want to verify I have the connections made in the correct order/scheme. It appears obvious the red connectors are to the red selonoids and the white connectors to the blue selonoids...but what I want to confirm is the correct orientation of the connector slots on each...when looking down on the assembly from the top (connectors on the top with white connectors above the red) ), should the orange wires be oriented on the top or bottom for each connector? ( see below )...........
- orange wire
white connector--
- yellow wire
- orange wire
red connector--
- white wire
Ads By Google
Related Models
