Discuss
replacement ptc
 in
Refrigerator & Freezer Repair
I believe I have my fridge problem narrowed to the ptc. I received the replacement part but it only has
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » replacement ptc
  #1 (permalink)
Old 10-23-2012, 09:45 AM
Junior Member
cmc66 is on a distinguished road
Default replacement ptc
Model Number: dff8804   Brand: -other-   Age: 5 - 10 years
I believe I have my fridge problem narrowed to the ptc. I received the replacement part but it only has 2 connectors while the old one has 3 (2 from the capacitor and 1 from the overload) The parts supplier assures me this is the correct replacement part but has been otherwise useless. Is there a way to connect this new part or is it possible I also need a different overload to accompany the new pts as it is not compatible with my old overload.
Ads By Google
Related Models
Maytag DFNF17  Freezer - Vertical
Amana DFS11E Commercial Microwaves
Menu Master DFS11EA  Commercial Microwaves
Amana DFS16 Freezer - Chest
Menu Master DFS18E  Commercial Microwaves
Amana DFU17 Freezer - Vertical
Amana DFU17L Freezer - Vertical
Amana DFU18 Freezer - Vertical
Amana DFU18L Freezer - Vertical
Maytag DG100 Dryer - Gas
Maytag DG100PN1 Dryer - Gas
Maytag DG101 Dryer - Gas
Maytag DG102 Dryer - Gas
Amana DG1030 Washer - Top Loading
Amana DG1031 Washer - Top Loading
Maytag DG105 Dryer - Gas
Maytag DG106 Dryer - Gas
Maytag DG107 Dryer - Gas
Maytag DG110 Dryer - Gas
Maytag DG16CA Dryer - Gas
Maytag DG16CM Dryer - Gas
Maytag DG16CT Dryer - Gas
Maytag DG18CA Dryer - Gas
Maytag DG18CM Dryer - Gas
Maytag DG18CS Dryer - Gas
Maytag DG18CT Dryer - Gas
Admiral DG18F2AM Dryer - Gas
Admiral DG18F2HW Dryer - Gas
Admiral DG18F2WN Dryer - Gas
Admiral DG18F2WW Dryer - Gas
Maytag DG19CD Dryer - Gas
Maytag DG19CS Dryer - Gas
Maytag DG19CT Dryer - Gas
Frigidaire DG2000DL1 Frg(v1) / Gas Dryer
Frigidaire DG2000DW1 Frg(v2) / Gas Dryer
Magic Chef DG20F5AM Dryer - Gas
Magic Chef DG20F5FA Dryer - Gas
Magic Chef DG20F5HW Dryer - Gas
Magic Chef DG20F5WG Dryer - Gas
Magic Chef DG20F5WW Dryer - Gas
Admiral DG20F8AM Dryer - Gas
Admiral DG20F8HW Dryer - Gas
Admiral DG20F8WW Dryer - Gas
Maytag DG210 Dryer - Gas
Maytag DG212 Dryer - Gas
Maytag DG212D Dryer - Gas
Maytag DG21CA Dryer - Gas
Maytag DG21CM Dryer - Gas
Maytag DG21CS Dryer - Gas
Maytag DG21CT Dryer - Gas
Maytag DG22CA Dryer - Gas
Maytag DG22CS Dryer - Gas
Maytag DG22CT Dryer - Gas
Maytag DG23CD Dryer - Gas
Maytag DG24CA Dryer - Gas
Maytag DG24CM Dryer - Gas
Maytag DG24CS Dryer - Gas
Maytag DG24CT Dryer - Gas
Frigidaire DG250EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG250EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG250EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG250EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG250EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG250EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG250EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG250EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG250EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG250EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG250EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG250EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG250EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG250EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG250JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG250JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG250JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG250JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG250KXD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW4 Wwh(v1) / 27 " Gas Dryer
Maytag DG25CS Dryer - Gas
Maytag DG26CA Dryer - Gas
Maytag DG26CD Dryer - Gas
Maytag DG26CS Dryer - Gas
Maytag DG26CT Dryer - Gas
Frigidaire DG27A5WAFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WAFB Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WVFA Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WVFX Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WXFC Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFD Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFE Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFF Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A7WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WVFX Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFC Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFD Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFE Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A8WAFB Gib(v1) / 27 " Gas Dryer
Maytag DG27CA Dryer - Gas
Maytag DG27CD Dryer - Gas
Maytag DG27CS Dryer - Gas
Maytag DG27CT Dryer - Gas
Frigidaire DG27S6DTMA Gib(v1) / Gas Dryer
Frigidaire DG27S6DVFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27S6FTMA Gib(v3) / Gas Dryer
Frigidaire DG27S6WPMA Gib(v1) / Stackable Gas Dryers
Frigidaire DG27S6WPMB Gib(v2) / Stackable Gas Dryers
  #2 (permalink)
Old 10-23-2012, 09:50 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Nothing comes up with model number
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 10-23-2012, 10:10 AM
Junior Member
Default
Quote:
Its a danby fridge and parts are all supposed to be compatible with dff9100
my old ptc is 6r8md3 and the replacement sent was dff9100.46
A photo should also be attached
  #4 (permalink)
Old 10-23-2012, 11:06 AM
Expert
APP Volunteer
Default
I'll assume your capacitor is a run capacitor. There are only two wires that supply power to the compressor. The overload connects to the common terminal on the compressor. That's where one wire goes (doesn't matter which one) the PTC device connects to the start terminal and the run terminal on the compressor. The other wire connects to the terminal over the run terminal. The three compressor pins are in a triangle configuration. The top of the triangle is the common terminal. On the bottom of the triangle, start terminal on left and run terminal on the right. So when you connect the overload and PTC device, one wire on top and one on bottom right. The capacitor connects to the two terminals on the new PTC device
__________________
  #5 (permalink)
Old 10-23-2012, 11:58 AM
Junior Member
Default
There is a 2 wire set from the capacitor and another 2 wire set which with the old ptc one wire connects to the 3rd prong on the ptc and the other to the overload. The compressor starts and hums for 10-15 secs and then it clicks off.
When I connect the ptc to the capacitor and just connect 1 of the other wires to the overload (tried both) and leave one disconnected the fridge will not come on when plugged back in.
It looks to me with the other 2 wire set one is coupled with the black from the power cord and the other runs with other wires up towards the freezer where all the other connections are.
Is it safe to assume then that although the part supplier reassures me this is the proper replacement part that It cannot work and I need on with the 3rd connection on the ptc.
Also I tested the compressor because I wasn't going to repair the fridge if it was shot. The common to the start read approx. 6ohm as did the common to the run. The start to the run read approx. 12ohm so it should be in good
shape since 6+6=12?
Thanks a lot for all your help. I've been trying to troubleshoot this thing for way too long.
  #6 (permalink)
Old 10-23-2012, 12:20 PM
Expert
APP Volunteer
Default
Quote:
Sorry, but I couldn't make heads or tails out of that sentence. Take a pic of the old parts on the compressor and I'll draw you a picture
__________________
  #7 (permalink)
Old 10-24-2012, 03:53 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
The two power wires from the refigerator go to the overload and the right pin of the ptc. The run capacitor must be wired between the opposite ptc terminals. You will need to splice wires to do this. If the old ptc device was wired that way, you are probably ok. If not, you have probably burnt open/burned the start winding of the compressor. It is not possible to verify correct wiring as the schematic will not show that.
Usually, the higher resistance as measured from the top, common terminal of the comprerssor and to one of the botom terminals designates the start winding and the other bottom terminal, the run winding.On most compressors, the bottom, left terminal is the start winding. To observe the difference, you would need an accurate, digital meter.
If you have the old ptc, hold the device with the tab on the top and the input spade terminals facing you. The resistance from the right spade terminal to the right output compressor terminal must be a short. The resistance from the same spade terminal to the left output terminal should show about 5 ohms.If open,it is blown. If the new ptc device measures correctly, you have the right ptc device.
Also, on this forum I have stated often, the compressor windings can be a charred mess and still show perfectly "normal" resistance with a 9 volt meter!
__________________
  #8 (permalink)
Old 10-24-2012, 05:05 PM
Junior Member
Default
Can the compressor be that "charred mess" and still run? I connected the old ptc back again last night and everything was running seemingly normal for maybe 8 hours except it still isn't cooling. Compressor was running and could hear the sound of coolant. I advanced the defrost timer and turned the cold control off and on a few times during that time. Late last night it got back to the hum for 10-15 seconds and clicked off when trying to start up.
I have also replaced the defrost thermostat, defrost timer and cold control.
Also going back a bit further I first experienced the problem of the fridge not blowing cold after I got back from holidays in january and it was completely warm. I unplugged it then plugged it back in and it ran fine up until recently.
Any thoughts would be quite helpful as I am almost ready to give up!
  #9 (permalink)
Old 10-25-2012, 01:34 AM
Senior Expert
APP Volunteer
Default
If the compressor was vibrating, but the evaporator coils where not cold, you have a bad refrigerant leak/ bad compressor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F11 still after ccu replacement fiercefun Washer Repair 2 04-14-2012 09:23 AM
Tub Replacement CLOMJM Washer Repair 2 04-11-2011 05:10 PM
Mtr replacement Dannyk Dishwasher Repair 1 08-13-2010 07:15 AM
Hub Nut replacement epenameza Washer Repair 0 05-16-2010 10:05 AM
EOC replacement jodiw Oven Repair (including Ranges and Cooktops) 1 05-06-2009 09:00 PM
