| » The Roach did it! |
Hi.
It's not likely that you broke the freon line with wooden stick. Let the fridge run for an hour and then check if the condenser fan motor is running (next to the compressor), evaporator fan running (inside the freezer). Open the rear panel in the freezer and check if the evaporator coils are covered with frost. Post the model and manufacturer numbers. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Could be a coincidence that the fridge went into a defrost cycle (compressor and fans will be off) while you were roach hunting.
As Simon said let it run for a while before deciding it needs repair. I will keep my fingers crossed.
__________________
| Display Modes | |
