Discuss
Unusual Ice Maker Problem
 in
Refrigerator & Freezer Repair
I have a Kenmore Elite Side by Side with the standard Whirlpool ice maker. The infrared blinks correctly. The ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Unusual Ice Maker Problem
  #1 (permalink)
Old 10-22-2012, 11:58 AM
Junior Member
danwd1 is on a distinguished road
Default Unusual Ice Maker Problem
Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore Elite Side by Side with the standard Whirlpool ice maker. The infrared blinks correctly. The ice maker motor wont run when I jump T & H. I tested line voltage at the ice maker and found 98 volts. I removed the ice maker and tested the connector at the freezer wall, 98 volts. I connected the L1 & L2 at the connector on the ice maker that plugs into the freezer wall connector to outlet voltage of 125 volts, jumped T & H and the motor ran. I removed the jumper wire and the motor completed 1 full cycle and stopped. I assume that the low ( 98 volts ) at the freezer connector is too low to run the 120 volt motor. I can't find a wiring schematic but nonetheless if the voltage is that low, that is why it wont run. Any thoughts? I did try a new motor / module assembly and still no run.
Ads By Google
  #2 (permalink)
Old 10-23-2012, 11:10 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Replace the optics. That's what is causing the low voltage.
__________________
Ricks Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sharp Microwave Unusual Problem JEFF941 Microwave Repair 1 08-21-2012 11:23 AM
Unusual Refrigerator Problem LTColumbo Refrigerator & Freezer Repair 4 07-11-2011 04:45 AM
Unusual Noises alhhaney Dishwasher Repair 15 05-19-2010 05:52 AM
timer goes off at unusual times kybrown Oven Repair (including Ranges and Cooktops) 1 11-28-2009 09:10 PM
Unusual question Elena General Talk 6 12-20-2007 12:27 PM
