| » Defrost Timer |
Model Number: MFH2568AES Brand: Maytag Age: 1 - 5 years
I have a Maytag french door refrigerator that is acting erratic. It started when the fridge stop cooling. The fan was still running but the compressor would not come on. I checked the capacitor and relay and both are fine. I searched all over for a defrost timer to see if it was stuck in defrost mode. I could not find one which leads me to think that it is electronic. There is a large circuit board (about 6" x 8") on the back left side at about waist level. I put everything back together and plugged it back in and it started working again.
Any ideas of what the problem might be? Ads By Google Related Models |
Sorry, It looks like I typed in the number wrong. It is MFI2568AES. I appreciate any help you can offer. It started working after I had it unplugged and plugged back in again for about a day. This morning when I got up is was 63 degrees in the fridge.
That model has a service diagnostic test built into the control board. You'll need your tech sheet for the correct steps and component tests. Look behind the lower kick plate on the right side. It may be taped to the bottom of the machine in an envelope. It may also be inside the control housing.
__________________
Ricks Appliance Repair |
I found the tech sheet taped under the front right corner under the fridge but it has no instructions on how to get into the service mode. I checked the control board and there are no switches. I assume that it is probably a combination of button pushes and/or holds on the front panel but I have know clue where to start. I've tried several combinations but nothing.
Any ideas? |
Parts for Maytag MFI2568AES Refrigerator - AppliancePartsPros.com See the attachment for a tech sheet Originally you said the fan was running. Which fan? the condenser/compressor fan and/or the evaporator/freezer fan. If the condenser fan was running then it is probably a compressor or start/overload device problem. As the compressor is wired in parallel with the fan so when one is on the other should also be on.
__________________
Ok, I found a service manual online that gave me instructions on how to get into the service mode. The only thing I've tried so far is to set the defrost mode to factory default. That didn't work. What puzzles me is that after the fridge is unplugged for awhile the compressor will start working and it will cool down to normal temerature. Sometime overnight it stops working because when I get up in the morning the fan is running but not the compressor and it is over 60 degrees in the fridge compartment. It seems to me that if it were a themostat or sensor that has failed that it would never start to begin with or run forever. I hate to spend the money for a new control board without knowing that that is the fix but I'm not sure what to test. Any ideas would be greatly appreciated.
| Display Modes | |
| Defrost Timer or defrost circuit part of Control Board? | c6timmons | Refrigerator & Freezer Repair | 0 | 08-21-2012 12:56 PM |
| Does my Maytag have a defrost timer or adaptive defrost control? Where is it? | Momto8 | Refrigerator & Freezer Repair | 13 | 06-18-2012 06:37 PM |
| new defrost timer wont come out of defrost | jfmorton | Refrigerator & Freezer Repair | 1 | 04-01-2010 01:02 PM |
| I still have froze in the freezer after changing defrost timer & bi-metal defrost | matteson | Refrigerator & Freezer Repair | 0 | 12-29-2009 06:25 PM |
| Defrost timer only works in defrost cycle | george10 | Refrigerator & Freezer Repair | 2 | 07-18-2009 06:15 PM |
