Discuss
water comming up in fridge from using water in door
 in
Refrigerator & Freezer Repair
what would cause the fridge under the crisper tray to fill up as you get water from the other side?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water comming up in fridge from using water in door
  #1 (permalink)
Old 10-21-2012, 05:36 PM
Junior Member
goverton is on a distinguished road
Default water comming up in fridge from using water in door
Brand: Kenmore   Age: 5 - 10 years
  #2 (permalink)
Old 10-21-2012, 07:21 PM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
The water storage reservoir/coil is behind the crispers and probably has a leak in it. If it turns out to be a small hole or cut in the coil, use a razor blade to cut the bad spot out then use a John Guest coupler to join the two ends. If it's a large leak or more than one, replace the entire coil.
__________________
Ricks Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water refilling ice or water dispenser=water spraying in fridge cheshirekitti Refrigerator & Freezer Repair 2 01-30-2012 09:28 AM
Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water ugagrad04 Refrigerator & Freezer Repair 0 07-20-2010 06:43 PM
No ice or water comming out of the dipenser KANDA Refrigerator & Freezer Repair 0 07-13-2010 11:35 AM
Ice Maker unable to dump ice (no water comming in) lpetitjean Refrigerator & Freezer Repair 1 10-04-2009 08:58 PM
water is not comming in ren Dishwasher Repair 1 08-07-2007 09:17 PM
