Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   water comming up in fridge from using water in door (http://forum.appliancepartspros.com/refrigerator-freezer-repair/503928-water-comming-up-fridge-using-water-door.html)
goverton 10-21-2012 06:36 PM
what would cause the fridge under the crisper tray to fill up as you get water from the other side?
rickgburton 10-21-2012 08:21 PM
The water storage reservoir/coil is behind the crispers and probably has a leak in it. If it turns out to be a small hole or cut in the coil, use a razor blade to cut the bad spot out then use a John Guest coupler to join the two ends. If it's a large leak or more than one, replace the entire coil.
