Discuss
amana side by side refrigerator water line inside freezer door leaking
 in
Refrigerator & Freezer Repair
Hello, This is an old refrigeratior/freezer, but everything else works great. water just started dripping from bottom of freezer door.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » amana side by side refrigerator water line inside freezer door leaking
  #1 (permalink)
Old 10-21-2012, 10:01 AM
Junior Member
borth is on a distinguished road
Smile amana side by side refrigerator water line inside freezer door leaking
Model Number: sdr25s5l   Brand: Amana   Age: More than 10 years
Hello, This is an old refrigeratior/freezer, but everything else works great. water just started dripping from bottom of freezer door. at first it was a very slow leak but leak is getting worse. dispenser and ice maker work fine. exposed tubing going into door looks to be in good shape so must be a crack in tubing inside freezer door. is it a major repair to replace tubing or can it even be replaced? can I disconnect water going to dispenser but still keep water going to ice maker so it will work?
thanks for your help,
Brad
Ads By Google
Related Models
Whirlpool SDU30000
Whirlpool SDU30001
Whirlpool SDU30002
Whirlpool SDU30003
Whirlpool SDU30010
Whirlpool SDU30011
Whirlpool SDU30012
Whirlpool SDU30013
Whirlpool SDU30014
Whirlpool SDU30015
Whirlpool SDU30016
Whirlpool SDU40000
Whirlpool SDU40001
Whirlpool SDU40010
Whirlpool SDU40011
Whirlpool SDU40012
Whirlpool SDU45011
Whirlpool SDU45012
Whirlpool SDU50000
Whirlpool SDU50001
Whirlpool SDU50002
Whirlpool SDU50003
Whirlpool SDU50010
Whirlpool SDU50011
Whirlpool SDU50012
Whirlpool SDU50013
Whirlpool SDU50014
Whirlpool SDU60000
Whirlpool SDU60001
Whirlpool SDU60010
Whirlpool SDU60011
Whirlpool SDU60012
Whirlpool SDU70000
Whirlpool SDU70001
Whirlpool SDU70010
Whirlpool SDU70011
Whirlpool SDU70012
Whirlpool SDU70013
Whirlpool SDU70020
Whirlpool SDU80000
Whirlpool SDU80001
Whirlpool SDU80010
Whirlpool SDU80011
Whirlpool SDU80012
Whirlpool SDU90000
Whirlpool SDU90001
Whirlpool SDU90010
Whirlpool SDU90011
Whirlpool SDU90012
Maytag SE1000 Stacked Laundry - Ele
Maytag SE1000T Stacked Laundry - Ele
Maytag SE7800 Stacked Laundry - Ele
Whirlpool SE950PEKW0
Whirlpool SE950PEKW1
Whirlpool SE950PEPW0
Whirlpool SE950PERW0
Whirlpool SE950PERW1
Whirlpool SE950PERW2
Whirlpool SE950PERW3
Whirlpool SE950PERW4
Whirlpool SE950PERW5
Whirlpool SE950PERW6
Whirlpool SE950PERW7
Whirlpool SE950PERW8
Whirlpool SE950PERW9
Whirlpool SE950PSKW0
Whirlpool SE950PSKW1
Whirlpool SE950PSPW0
Whirlpool SE953PEKT0
Whirlpool SE953PEKT1
Whirlpool SE953PSKT0
Whirlpool SE953PSKT1
Whirlpool SE960PEPW0
Whirlpool SE960PEPW1
Whirlpool SE960PEPW2
Whirlpool SE960PEPW3
Whirlpool SE960PEPW4
Whirlpool SE960PEPW5
Whirlpool SE960PEPW6
Whirlpool SE960PEYN1
Whirlpool SE960PEYN2
Whirlpool SE960PEYN3
Whirlpool SE960PEYW0
Whirlpool SE960PEYW1
Whirlpool SE960PEYW2
Whirlpool SE960PEYW3
Maytag SE9900 Stacked Laundry - Ele
Whirlpool SEC350XW0
Whirlpool SEC350XX1
Whirlpool SEDS800HQ0
Whirlpool SEDS800JQ0
Whirlpool SEDS800JQ1
Whirlpool SEDS800MQ0 29"electric Dryer
Whirlpool SEDS800MQ1 29"electric Dryer
Whirlpool SEDX600HQ0
Whirlpool SEDX600JQ0
Whirlpool SEDX600JQ1
Whirlpool SEDX600MQ0 29"electric Dryer
Whirlpool SEDX600MQ1 29"electric Dryer
Amana SEFS65D Commercial Microwaves
Jenn-Air SEG196 Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W-C Range - S/c S/i Gas & Elec Duel Fuel
Whirlpool SEP340XX0
Whirlpool SEP340XX1
White Westinghouse SER341AQ0 Dryer - W.west
White Westinghouse SER341AQ1 Dryer - West/grupo Gomo
White Westinghouse SER341AQ2 White Westinghouse/electric Dryer
White Westinghouse SER341AS0 Dryer - W.west
White Westinghouse SER341AS1 Dryer - West/grupo Gomo
White Westinghouse SER341AS2 White Westinghouse/electric Dryer
Whirlpool SES370XX0
Whirlpool SES374HQ0
Whirlpool SES374HQ1
Whirlpool SES380MS0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool SF0100EKW0
  #2 (permalink)
Old 10-21-2012, 01:45 PM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Disconnect the water line connector and wire connector by the lower door hinge. Remove the upper freezer door hinge. Lift the door off and lay it on a flat surface. Remove the screws behind the door seal then lift the liner and door seal off or slide it over to access the water line. Use 1/4" line.
__________________
Ricks Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do I replace water line in freezer door of whirlpool side by side Todd Overton Refrigerator & Freezer Repair 33 02-18-2013 05:19 PM
Removing Freezer door/water line on side-by-side to install new cam riser RSMBob Refrigerator & Freezer Repair 3 03-05-2012 01:37 PM
Side by Side model freezer door keeping water line frozen fisshen99 Refrigerator & Freezer Repair 0 11-14-2010 02:12 PM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 1 03-30-2010 11:18 PM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 0 03-21-2010 08:04 PM
