Discuss
side by side refrigerator freezer
 in
Refrigerator & Freezer Repair
I discovered a coil in the inside of the freezer that is over heating and turnning red hot and melting
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » side by side refrigerator freezer
  #1 (permalink)
Old 10-18-2012, 04:48 PM
Junior Member
nking is on a distinguished road
Default side by side refrigerator freezer
Brand: Frigidaire   Age: 5 - 10 years
I discovered a coil in the inside of the freezer that is over heating and turnning red hot and melting ice and causing a leek on my kitchen floor is this somthing that can be repaired or should I just purchase a new fridge?
Ads By Google
  #2 (permalink)
Old 10-20-2012, 04:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help other help you.
Sounds like the drip tray drain is plugged so every time the unit does a defrost the water ends up on the floor.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tray after you are done.
Be sure to unplug the unit while doing this.
Also on many units the heater does get very hot but once the ice/frost is off the evaporator coils it should shut off.
The heater has a thermostat wired in series with he heating coil, it opens just above freezing killing power to the heater.
So at room temperature it should be infinite ohms.
Also if it is deformed (bulged) replace it even if it measures OK.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
Refrigerator runs continuosly, freezer side is very cold & fridge side is 28 F pgrose Refrigerator & Freezer Repair 0 06-01-2011 10:21 AM
My Frigidaire Side by Side Refrigerator/Freezer is freezing my refrigerator items hpalmatier Refrigerator & Freezer Repair 2 11-30-2010 06:41 AM
Frigidaire side by side refrigerator freezer working refrigerator not cold enough SSOWDERS Refrigerator & Freezer Repair 1 09-19-2009 09:00 AM
Side by Side refrigerator/freezer side not cool baq66 Refrigerator & Freezer Repair 5 08-03-2009 09:07 AM
