Discuss
magic chef refridgerator
 in
Refrigerator & Freezer Repair
I received this refridgerator from a neighbor - i believe she had it for about 1 -2 yrs. it had
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » magic chef refridgerator
  #1 (permalink)
Old 10-18-2012, 02:12 PM
Junior Member
ksopoci is on a distinguished road
Post magic chef refridgerator
Model Number: CSD2123ARW   Brand: Magic Chef   Age: 1 - 5 years
I received this refridgerator from a neighbor - i believe she had it for about 1 -2 yrs. it had a water and ice dispenser which i have not hooked up yet. i have no manuals- the first problem i am having is that i am getting water in the freezer which runs to the bottom and freezes so i am constantly breaking up ice on the bottom- the other problem i am having is in the fridge - the bottom drawer freezes anything i put in their= i have the side setting on cool not on cold. and sometimes i get leakage from under neath the fridge. Please let me know your thoughts tks Kat
Ads By Google
Related Models
Magic Chef CSD2123ARW Ref - SXS/I&W
Magic Chef CSD2324ARA Ref - SXS/I&W
Magic Chef CSD2324ARW Ref - SXS/I&W
Magic Chef CSD2325ARA Ref - SXS/I&W
Magic Chef CSD2325ARB Ref - SXS/I&W
Magic Chef CSD2325ARW Ref - SXS/I&W
Magic Chef CSD2524ARA Ref - SXS/I&W
Magic Chef CSD2524ARW Ref - SXS/I&W
Magic Chef CSD2525ARA Ref - SXS/I&W
Magic Chef CSD2525ARB Ref - SXS/I&W
Magic Chef CSD2525ARW Ref - SXS/I&W
Magic Chef CSD2610KRW Ref - SXS/I&W
Magic Chef CSD2725ARA Ref - SXS/I&W
Magic Chef CSD2725ARB Ref - SXS/I&W
Magic Chef CSD2725ARW Ref - SXS/I&W
Amana CSDI25A Ref - SXS/I&W
Amana CSDI25A-A Ref - SXS/I&W
Amana CSDI25A-AG Ref - SXS/I&W
Amana CSDI25A-C Ref - SXS/I&W
Amana CSDI25C Ref - SXS/I&W
Amana CSDI25C-A Ref - SXS/I&W
Amana CSDI25C-C Ref - SXS/I&W
Amana CSDI25C-G Ref - SXS/I&W
Amana CSDI25C-L Ref - SXS/I&W
Amana CSDI25D Ref - SXS/I&W
Amana CSDI25E Ref - SXS/I&W
Amana CSDI25E-A Ref - SXS/I&W
Amana CSDI25E-C Ref - SXS/I&W
Amana CSDI25E-G Ref - SXS/I&W
Amana CSDI25E-L Ref - SXS/I&W
Amana CSDI25W Ref - SXS/I&W
Amana CSDI25W-A Ref - SXS/I&W
Amana CSDI25W-AG Ref - SXS/I&W
Amana CSDI25W-C Ref - SXS/I&W
Amana CSDI25W-L Ref - SXS/I&W
General Electric CSE20ERAWH Refrigerator
General Electric CSE22DRAWH Refrigerator
General Electric CSE22GMA Refrigerator
General Electric CSE24DRAWH Refrigerator
General Electric CSE27DRAWH Refrigerator
Whirlpool CSE3A1
Whirlpool CSE3W1
Maytag CSE400 Surface Unit - Ele
Maytag CSE4000ACB Surface Unit - Ele
Maytag CSE4000ACD Surface Unit - Ele
Maytag CSE4000ACE Surface Unit - Ele
Maytag CSE4000ACL Surface Unit - Ele
Maytag CSE4000ACW Surface Unit - Ele
Maytag CSE4000ADW Surface Unit - Ele
Whirlpool CSE5A2
Whirlpool CSE5W2
Maytag CSE600 Surface Unit - Ele
Maytag CSE601 Surface Unit - Ele
Maytag CSE6010ACB Surface Unit - Ele
Maytag CSE6010ACD Surface Unit - Ele
Maytag CSE6010ACE Surface Unit - Ele
Maytag CSE6010ACL Surface Unit - Ele
Maytag CSE6010ACW Surface Unit - Ele
Maytag CSE7000ADB Surface Unit - Ele
Maytag CSE7000ADE Surface Unit - Ele
Maytag CSE800 Surface Unit - Ele
Maytag CSE8000ACB Surface Unit - Ele
Maytag CSE8000ACE Surface Unit - Ele
Maytag CSE8000ADB Surface Unit - Ele
Maytag CSE8000ADE Surface Unit - Ele
Maytag CSE900 Surface Unit - Ele
Maytag CSE9000ACB Surface Unit - Ele
Maytag CSE9000ACE Surface Unit - Ele
Maytag CSE9000ADB Surface Unit - Ele
Maytag CSE9000ADE Surface Unit - Ele
Maytag CSE9000BCB Surface Unit - Ele
Maytag CSE9000BCM Surface Unit - Ele
Maytag CSE9000BCQ Surface Unit - Ele
Maytag CSE9000BDB Surface Unit - Ele
Maytag CSE9000BDE Surface Unit - Ele
Maytag CSE9000CDB Surface Unit - Ele
Maytag CSE9000CDE Surface Unit - Ele
Maytag CSE9000DDB Surface Unit - Ele
Maytag CSE9000DDE Surface Unit - Ele
Maytag CSE9600ACB Surface Unit - Ele
Maytag CSE9600ACE Surface Unit - Ele
Maytag CSE9900ACB Surface Unit - Ele
Maytag CSE9900ACE Surface Unit - Ele
Admiral CSEA300ACD Surface Unit - Ele
Admiral CSEA300ACE Surface Unit - Ele
Admiral CSEA300ACL Surface Unit - Ele
Admiral CSEA500ACB Surface Unit - Ele
Admiral CSEA500ACE Surface Unit - Ele
General Electric CSF19AYX Refrigerator
General Electric CSF20AAB Refrigerator
General Electric CSF20ABC Refrigerator
General Electric CSF20ABM Refrigerator
General Electric CSF20ACB Refrigerator
General Electric CSF20ACM Refrigerator
General Electric CSF20EAB Refrigerator
General Electric CSF20EAS Refrigerator
General Electric CSF20EBC Refrigerator
General Electric CSF20EBD Refrigerator
General Electric CSF20EBF Refrigerator
General Electric CSF20EBG Refrigerator
General Electric CSF20EBM Refrigerator
General Electric CSF20ECB Refrigerator
General Electric CSF20ECC Refrigerator
General Electric CSF20ECM Refrigerator
General Electric CSF22EBC Refrigerator
  #2 (permalink)
Old 10-20-2012, 05:21 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram.
Parts for Magic Chef CSD2123ARW Refrigerator - AppliancePartsPros.com
Sounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan.
I would check that it is clear.
You will have to remove the cover in the freezer to get at it. It is under the evaporator coils.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tray after you are done.
Also check that the drain pan is not cracked.
Would also be a good idea to clean the condenser coils under the unit, including the condenser/compressor fan blades.
Check that when the compressor is on that the condenser fan is also on.
The fan not only cools the compressor and it's coils but also helps evaporate the water from defrost.
Also that any vents in the front kick plate and rear compressor compartment cove are clean.
Be sure to unplug the unit while doing this.
On the freezing food in the fresh food side.
Check that the evaporator/freezer fan is running.
There is usually a vent in the wall between the fresh food side and the freezer side check that it is clear on both sides.
Check your temperatures. The freezer should be 0 to 5 degrees F. The fresh food should be around 40 degrees F., thermometer placed on a middle shelf.
Check that the control actually opens/closes the damper door (Item 11 in the Controls section). This is a mechanical only damper so the freezer temperature has a large effect on the fresh food temperature.
If after all the above if it still gets water on the floor check the door seals, perhaps they are leaking and letting too much warm/moist air into the unit so you end up with excessive frost on the evaporator coils.
take a 2 inch wide strip of paper, place it between the seal and the frame, then pull it out to see how it is sealing.
If it does not seal OK.make sure the unit is either level or leaning slightly to the back.
Most units have plastic cams on the lower door hinges, check that they are OK.
Check the hinge side seal. If they grab and twist when closing the door, apply a light coat of white lithium gease or vaseline so they will slip and seal correctly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Lois Tetzlaff Oven Repair (including Ranges and Cooktops) 0 11-27-2010 10:07 AM
magic chef tomtieppo Oven Repair (including Ranges and Cooktops) 3 11-26-2010 07:15 AM
Magic Chef Won't Run Kountryguy Refrigerator & Freezer Repair 2 07-11-2010 06:08 PM
magic chef elizabeth reiling Refrigerator & Freezer Repair 1 01-04-2010 02:46 PM
magic chef/ no magic wayne scott Oven Repair (including Ranges and Cooktops) 2 03-28-2009 01:43 PM
