| » aaaaafridge and Freezer not cooling |
Model Number: GX5SHDXVY00 Brand: Whirlpool Age: 1 - 5 years
Neither the refrigerator nor the freezer are getting cold. When it is left to run for a period of time the compressor gets hot but does not click or sound like it is cycling on. Both the coil fan and the condensor fan are running but both are only blowing ambient air. The interior cabinet is at room temperature and has been that way for twenty four hours now so it is very unikely there is any frost on the coils. also the condensor coils are clean. This fridge is located here in Port Au Prince Haiti and is constanly subjected to low power supply from the power company because so many people home here illegally tap in the power transmittion lines.
Hi.
When the fridge is on put your hand on the compressor and check if you can fill vibration. If not then unplug it and remove the start relay/overload from the compressor and shake it. If it rattles - replace it Part number: W10128791 Before ordering a part using multimeter check the continuity between the compressor's pins and then to the ground. If the pins have continuity and no continuity to the ground then order the start devise. Check the voltage at the outlet. The fridge wont work if there is less then 110VAC. Here are the breakdown diagrams and Unit parts for Whirlpool GX5SHDXVY00 - AppliancePartsPros.com Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| refridgerator not cooling. freezer is cooling fine | Debbie Ash | Refrigerator & Freezer Repair | 0 | 08-24-2011 10:17 AM |
| GE Fridge/Freezer Not Cooling Freezer Properly | woody1397 | Refrigerator & Freezer Repair | 1 | 02-02-2011 06:56 PM |
| Freezer is not cooling | resxwni01 | Refrigerator & Freezer Repair | 4 | 11-10-2010 02:11 PM |
| Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling | angiebritt | Refrigerator & Freezer Repair | 3 | 07-22-2010 04:28 PM |
| Freezer not cooling | tfp098 | Refrigerator & Freezer Repair | 3 | 11-06-2009 04:35 PM |
