| » water coming from behind assy motor dampener cover |
Model Number: PFSF6PKXEWW Brand: GE Age: 1 - 5 years
I have a GE model PFSF6PKXEWW fridge. i found water inside the main fridge. I traced it back to the assembly cover motor dampener. i removed that and found water inside. it appears to be actually coming down a vent behind the motor dampener inside an air vent. please help me figure out where the water is coming from so i can stop it.
thanks http://www.********************.com/...E&Type=&Mark=6 Ads By Google Related Models |
Hi.
The first thing to check is the refrigerator door gasket. See if it's sealing good. Is the fridge temperature OK? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
seals are fine. holds temp great. i pulled assembly 97 form inside the main compartment, and yes, the drain was iced over. i cleared it out by chipping and flushing hot water through it until it woudl run straight through. then i put it all back together. about an hour later, a larege amount of water was colected at the bottom again under the deli tray. it was coming out of part 120, and the back of part 121 was soaked. please help.
Remove the evaporator cover (#97 at the diagram). Make sure that the heat tab is inserted into the drain tray outlet.
Pull the refrigerator out of the wall and remove the cover from the unit compartment. Make sure that the fresh food drain tube (look at the attached picture) is not clogged. Here are the breakdown diagrams and Parts for GE PFSF6PKXEWW Refrigerator - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 10-16-2012 at 04:25 PM. |
| Display Modes | |
| Loud buzzing coming from the control assy. | Gut_feeling | Refrigerator & Freezer Repair | 0 | 05-04-2011 11:13 AM |
| tub cover assy. replacement | jscon40 | Washer Repair | 1 | 03-29-2011 07:35 PM |
| Pump motor assy | man1repair | Refrigerator & Freezer Repair | 1 | 12-15-2010 03:07 AM |
| pump motor assy failure | diyCA | Dishwasher Repair | 1 | 07-07-2008 11:02 AM |
| Dishwasher motor assy | jcorr | Dishwasher Repair | 2 | 06-20-2008 02:49 PM |
