Discuss
Upright Freezer Help Needed
 in
Refrigerator & Freezer Repair
Hello All! So happy to find this forum!! Hope someone can help me out. Old "Imperial Heavy Duty Commercial Freezer",
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright Freezer Help Needed
  #1 (permalink)
Old 10-12-2012, 01:39 PM
Junior Member
Gerardp is on a distinguished road
Default Upright Freezer Help Needed
Model Number: UL1950ECW2   Brand: -other-   Age: More than 10 years
Hello All!
help me out.
Old "Imperial Heavy Duty Commercial Freezer", at least
that is what is on the door. Managed to salvage from a
bait shop that went under. Has worked fine for 2 years,
I believe the model is from 1991.
Recently, what used to be 11 degrees solid has gone up
to 40 plus. Removed back section inside freezer to check
coils, which were nice and clean. Fan up top of coils is
clear and spinning freely. Styrofoam "housing" around ther-
mometer dial has broken, but dial still works: shuts off and
turns on anyway.
The machine compressor works for about 10-15 seconds and
then turns off...at least I think its the compressor that is making
the noise.
I've tried to find a manual online, but from all indications, Imperial
has changed or been bought by Fridgidaire and no parts of my
numbers are being located. Very frustrating.
Either I fix this box, or I turn it into a food smoker!!
Any help would be greatly appreciated!!
Gerard
Ads By Google
Related Models
Frigidaire UL1950ECW2
Frigidaire UL1950ECW3
Frigidaire UL1950ECW4
Frigidaire UL1991ECW1
Frigidaire UL1991ECW2
Frigidaire UL1991ECW3
Frigidaire UL1991ECW4
Frigidaire UL19AHGD
Frigidaire UL2030ECW1
Frigidaire UL2030ECW12
Frigidaire UL2030ECW13
Frigidaire UL2030ECW2
Frigidaire UL2030ECW3
Frigidaire UL2030ECW4
Frigidaire UL2030ECW5
Frigidaire UL2030ECW7
Frigidaire UL2030ECW8
Frigidaire UL2075ECW1 Wwh(v1) / Upright Freezer
Frigidaire UL2075ECW2
Frigidaire UL2075ECW3
Frigidaire UL2075ECW4
Frigidaire UL2100CA1
Frigidaire UL2100CA2
 UL2100CA6 BROICH/FREEZER
 UL2100CA8 BROICH/FREEZER
Frigidaire UL2100ECW0
Frigidaire UL2100ECW1
Frigidaire UL2100ECW3
Frigidaire UL2164ECW1 Wwh(v1) / Upright Freezer
Frigidaire UL2164ECW2
Frigidaire UL2164ECW3
Frigidaire UL2164ECW4
Frigidaire UL2193ECW1
Frigidaire UL2193ECW2
Frigidaire UL2193ECW3
Frigidaire UL2193ECW4
Frigidaire UL2193ECW6
Frigidaire UL2193ECW7
Frigidaire UL2483ECW1 Wwh(v1) / Upright Freezer
Frigidaire UL2483ECW4
Frigidaire UL2493ECW1
Frigidaire UL2493ECW2
Frigidaire UL2493ECW3
Frigidaire UL2493ECW4
Frigidaire UL2493ECW5
Frigidaire UL2494CA0
Frigidaire UL2494CA5
Frigidaire UL2494CA6
Frigidaire UL2494ECW0
Frigidaire UL2494ECW10
Frigidaire UL2494ECW11
Frigidaire UL2494ECW2
Frigidaire UL2494ECW3
Frigidaire UL2494ECW4
Frigidaire UL2494ECW7
Frigidaire UL2494ECW8
 UL2500CA0 BROICH/FREEZER
Frigidaire UL4000CA0
Frigidaire UL4000ECW1
Frigidaire UL4000ECW2
Frigidaire UL4000ECW3
Frigidaire UL4000ECW4
Frigidaire UL4000ECW5
Frigidaire UL5000CA1
Frigidaire UL5000CA4
Frigidaire UL5000CA5
Frigidaire UL5000CA6
Frigidaire UL5000CA7
 UL5000CA8 BROICH/FREEZER
 UL5000CA9 BROICH/FREEZER
Frigidaire UL5000ECW0
Frigidaire UL5000ECW2
Frigidaire UL5000ECW3
Frigidaire UL5000ECW4
Frigidaire UL5000ECW5
Frigidaire UL5000ECW7
Amana ULD510 Commercial Microwaves
Amana ULD510M Commercial Microwaves
Amana ULD510S Commercial Microwaves
Amana UM2000C Commercial Microwaves
Amana UM2100.000 Commercial Microwaves
Amana UM3100.000 Commercial Microwaves
Maytag UMC1061AAB Mwave - Cntrtp / Stand Alone
Maytag UMC1061AAW Mwave - Cntrtp / Stand Alone
Maytag UMC1071AAB Mwave - Cntrtp / Stand Alone
Maytag UMC1071AAW Mwave - Cntrtp / Stand Alone
Maytag UMC5100ADB Mwave - Cntrtp / Stand Alone
Maytag UMC5100ADQ Mwave - Cntrtp / Stand Alone
Maytag UMC5100ADS Mwave - Cntrtp / Stand Alone
Maytag UMC5100ADW Mwave - Cntrtp / Stand Alone
Maytag UMC5200AAB Mwave - Cntrtp / Stand Alone
Maytag UMC5200AAQ Mwave - Cntrtp / Stand Alone
Maytag UMC5200AAS Mwave - Cntrtp / Stand Alone
Maytag UMC5200AAW Mwave - Cntrtp / Stand Alone
Maytag UMC5200BAB Mwave - Cntrtp / Stand Alone
Maytag UMC5200BAS Mwave - Cntrtp / Stand Alone
Maytag UMC5200BAW Mwave - Cntrtp / Stand Alone
Amana UMLD10E Commercial Microwaves
Amana UMLD10M Commercial Microwaves
Amana UMLD10SE Commercial Microwaves
Amana UMLD10SS Commercial Microwaves
Menu Master UMLD510  Commercial Microwaves
Menu Master UMLD510D  Commercial Microwaves
Amana UMP1.A Commercial Microwaves
Maytag UMV1142AAB Mwave - Mounted Under Cabinet
Maytag UMV1142AAQ Mwave - Mounted Under Cabinet
Maytag UMV1142AAW Mwave - Mounted Under Cabinet
Maytag UMV1142ACB Mwave - Mounted Under Cabinet
Maytag UMV1142ACQ Mwave - Mounted Under Cabinet
Maytag UMV1142ACW Mwave - Mounted Under Cabinet
Maytag UMV1152AAB Mwave - Mounted Under Cabinet
Maytag UMV1152AAQ Mwave - Mounted Under Cabinet
Maytag UMV1152AAW Mwave - Mounted Under Cabinet
Maytag UMV1152BAB Mwave - Mounted Over Range/wo
Maytag UMV1152BAQ Mwave - Mounted Over Range/wo
Maytag UMV1152BAS Mwave - Mounted Over Range/wo
Maytag UMV1152BAW Mwave - Mounted Over Range/wo
Maytag UMV1152CAB Mwave - Mounted Over Range/wo
Maytag UMV1152CAQ Mwave - Mounted Over Range/wo
  #2 (permalink)
Old 10-12-2012, 02:22 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Frigidaire UL1950ECW2 - AppliancePartsPros.com
You have to confirm that it is the compressor that is trying to start.
Then if it is following is some info on how to check it.
If it is OK then it may be the start relay or overload.
Notre: that if it checks out OK electrically it does not mean that the compressor is totally OK as it may have mechanical problems.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
__________________
  #3 (permalink)
Old 10-12-2012, 04:18 PM
Junior Member
Default
Quote:
Originally Posted by denman View Post
thank you so much...
Quick question..how do I confirm the compressor is trying to start?? It runs for about 10 seconds...gets warm, then quits..but it DOES start.
and like the idiot that I am...I thought the capacitor was the relay..thankfully the PDF file from below this thread set me straight!
This freezer may become a smoker yet!!
thanks again!!
  #4 (permalink)
Old 10-13-2012, 12:43 AM
Senior Expert
APP Volunteer
Default
Remove the back panel from the unit and listen. Also it should get warm and you should be able to feel it vibrate.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Upright Fridge/Freezer - Freezer not cold enough gstump Refrigerator & Freezer Repair 6 06-13-2012 01:51 PM
Upright freezer ffredvann Refrigerator & Freezer Repair 1 10-08-2008 05:20 PM
Upright Freezer Mik Refrigerator & Freezer Repair 8 03-31-2008 01:58 PM
