Register | FAQ's | New Posts | Today's Posts | Extras |
» How to check if compressor is running? |
![]() Model Number: FRS20ZRG Brand: Frigidaire Age: 5 - 10 years
![]() I have a silly question. Yesterday my side by side refrigerator went bad. Both compartments are warm. I have checked that both fans are working. I have checked the compressor for continuity between connectors, there were no problem. I have checked compressor for ground, it was ok too. So now is my problem, after I have plugged refrigerator to outlet. I can hear two fans and the compressor is making spinning noise for about a minute. Then it is very quiet and make very small vibration. It never get hot or even warmer than room temperature. The two lines that comes and goes from compressor don't change the temperature even after few hours when both fans were working all the time. My guts feeling was that start overload unit was basted (there is no rattle sound when shaking the starter) but I am not sure anymore. Any ideas why compressor don't warm up over the time. Is it normal it this refrigerator model? What is the simple test if compressor is running? Any ideas what I could check before buying new starter/overload unit? Thanks for your help. Walter Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi.
Please provide complete model number(two more numbers). Check the voltage at the compressor (should be 120VAC). Check the amps draw. You can try to replace the start components. If that doesn't help - the problem is most likely with compressor or the sealed system. In both cases you'll need a repairman. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
![]() Hi Simon,
It is model number that I found inside the refrigerator. Please tell me, if the compressor should be warm/hot when it runs. My makes humming noise but it is in the room temp. there is one tiny copper line that is cold and a little bit wet when touched. Beside this I can't tell if this compressor is doing anything. How fast I should feel cold inside the freezer after restart of the refrigerator? |
![]() Hi.
There is the sealed system problem. Could be low freon, restriction, compressor. Sounds like compressor is running. Put your hand on it, should feel vibration. My advise is to call a repairman. Simon.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
compressor check | birthdayparty | Refrigerator & Freezer Repair | 0 | 10-18-2011 08:39 AM |
Compressor relay: How to Check? | TomEH | Refrigerator & Freezer Repair | 7 | 04-27-2011 05:28 AM |
How to check to see if compressor is inop? | Clark Taylor | Refrigerator & Freezer Repair | 15 | 11-11-2010 07:07 PM |
How to check overload and compressor? | NarutoFan | Refrigerator & Freezer Repair | 6 | 10-27-2009 06:57 AM |
How to check compressor | gchardis | Refrigerator & Freezer Repair | 1 | 10-15-2009 04:41 AM |
