I have ordered part # 241734302 which is a water pump for the ice maker/water dispencer. It appears to be the correct part but my problem is that the part I have ordered has quick connects for the water tubes and the fridge has regular female threaded connections. Is there another part with the correct fittings or is there an adaptor that I could use?
Groups: APP Team
Hi.
Cut the ends of the water lines and just push in to the quick connects. Make sure they are in all the way.
Simon.
