| » Test a heater element??? |
Model Number: HSM25GFTASA Brand: Hotpoint Age: 5 - 10 years
I have a unit that the evaporator has consistantly frosted badly. I have already replaced the thermstat on the evaporator and the condenser fan.
The door gaskets are good and I don't suspect a refrigerant leak. I believe my defrost heating element may be the problem and I would like tp know if there are certain resistance (ohm) values to expect. Thank you for your help... Ads By Google Related Models |
Hi.
Turn the fridge off, remove the cover from the control board at the rear . Locate the J9 contact at the 3 wire plug and the J7 plug pin9.With one of the plugs removed check the resistance (freezer must be ice cold while checking). You should read at least 22 ohm. If there is no continuity -replace the defrost heater Part number: WR51X10055 If the resistance is OK - replace the control board Part number: WR55X10942 Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Most likely that what it is. Post the results. Simon.
__________________
| Display Modes | |
| How to Test Heating Element | Fishy2 | Dishwasher Repair | 2 | 04-30-2012 01:42 PM |
| Jumping Board to test Defrost Heater | oldschoolmc | Refrigerator & Freezer Repair | 1 | 12-24-2011 09:36 AM |
| Heater test | blitzen2 | Refrigerator & Freezer Repair | 2 | 12-03-2010 02:03 PM |
| how to test defrost heater | zrblazer | Refrigerator & Freezer Repair | 2 | 08-18-2009 05:19 AM |
| Clarification on heater test. | raimee | Dishwasher Repair | 1 | 06-24-2008 03:29 PM |
