Discuss
MZD2766GEW defrost problem
 in
Refrigerator & Freezer Repair
Hi, Looking for some help. I have a Maytag MZD2766GEW which is not defrosting on its own. I was able
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » MZD2766GEW defrost problem
  #1 (permalink)
Old 10-05-2012, 08:39 PM
Junior Member
mlabrie is on a distinguished road
Default MZD2766GEW defrost problem
Model Number: MZD2766GEW   Brand: Maytag   Age: 5 - 10 years
Looking for some help. I have a Maytag MZD2766GEW which is not defrosting on its own. I was able to locate the adaptive control board and it does not have the test pin to force a defrost. I found online that I could force a defrost by cycling the fridge on and off with the controls. I was able to do this, it took two forced defrosts to remove all of the frost.
I am not sure if this means the board is bad or good. We may have had this replaced once a few years ago. The coils iced over and eventually froze the fan and it stopped cooling. The repair guy replaced the fan and I believe a board of some type.
The defrost heater/switch seems to be one assembly with a three prong plug. I tested continuity through each pair of the plug and received readings on some but not all.
Couple of questions
1. If I can start a manual defrost, does this mean the board is good or bad?
2. Which pairs of plugs on the heater/switch test which item?
I greatly appreciate any help and guidance.
Matt.
Ads By Google
Related Models
Maytag MZD2766GEW Ref - SXS/I&W
Maytag MZD2768GEB Ref - SXS/I&W
Maytag MZD2768GEQ Ref - SXS/I&W
Maytag MZD2768GEW Ref - SXS/I&W
Norge N1100PAW Range - F/s Std Gas
Norge N1100PRA Range - F/s Std Gas
Norge N1100PRA-L Range - F/s Cont Clean Gas
Norge N1100PRW Range - F/s Std Gas
Norge N1100PRW-L Range - F/s Cont Clean Gas
Norge N1500PRA Range - F/s Std Ele
Norge N1500PRW Range - F/s Std Ele
Norge N31100PAA Range - F/s Std Gas
Norge N31100PAW Range - F/s Std Gas
Norge N3110KRA Range - F/s Std Gas
Norge N3110KRW Range - F/s Std Gas
Norge N3110PPA Range - F/s Std Gas
Norge N3110PPW Range - F/s Std Gas
Norge N3110PRA Range - F/s Std Gas
Norge N3110PRW Range - F/s Std Gas
Norge N31111XAA Range - F/s Std Gas
Norge N31111XAW Range - F/s Std Gas
Norge N31115WAV Range - F/s Std Gas
Norge N31115XAA Range - F/s Std Gas
Norge N31115XAW Range - F/s Std Gas
Norge N3120SPA Range - F/s Std Gas
Norge N3120SPN Range - F/s Std Gas
Norge N3120SPW Range - F/s Std Gas
Norge N3120SRA Range - F/s Std Gas
Norge N3120SRW Range - F/s Std Gas
Norge N3121XPA Range - F/s Std Gas
Norge N3121XPW Range - F/s Std Gas
Norge N3121XRA Range - F/s Std Gas
Norge N3121XRW Range - F/s Std Gas
Norge N3121XTA Range - F/s Std Gas
Norge N3121XTW Range - F/s Std Gas
Norge N3137XRA Range - F/s Std Gas
Norge N3137XRW Range - F/s Std Gas
Norge N3137XUA Range - F/s Std Gas
Norge N3137XUW Range - F/s Std Gas
Whirlpool N3157W0
Whirlpool N3157W1
Whirlpool N3157^0
Whirlpool N3157^1
Norge N3177VUV Range - F/s Std Gas
Norge N3177XRA Range - F/s Std Gas
Norge N3177XRW Range - F/s Std Gas
Norge N3177XUA Range - F/s Std Gas
Norge N3177XUW Range - F/s Std Gas
Whirlpool N3257W0
Whirlpool N3257W1
Whirlpool N3257^0
Whirlpool N3257^1
Whirlpool N3357W0
Whirlpool N3357^0
Norge N3422PRA Range - S/c F/s Gas
Norge N3422PRW Range - S/c F/s Gas
Norge N3438SRA Range - S/c F/s Gas
Norge N3438SRW Range - S/c F/s Gas
Norge N3438VRV Range - S/c F/s Gas
Whirlpool N3457W0
Whirlpool N3457^0
Norge N3472SRA Range - S/c F/s Gas
Norge N3472SRW Range - S/c F/s Gas
Norge N3478VRV Range - S/c F/s Gas
Norge N3478VVV Range - S/c F/s Gas
Norge N3478XRA Range - S/c F/s Gas
Norge N3478XRW Range - S/c F/s Gas
Norge N3478XVA Range - S/c F/s Gas
Norge N3478XVW Range - S/c F/s Gas
Norge N3510KRA Range - F/s Std Ele
Norge N3510KRW Range - F/s Std Ele
Norge N3510PPA Range - F/s Std Ele
Norge N3510PPW Range - F/s Std Ele
Norge N3510PRA Range - F/s Std Ele
Norge N3510PRW Range - F/s Std Ele
Norge N3520SPA Range - F/s Std Ele
Norge N3520SPN Range - F/s Std Ele
Norge N3520SPW Range - F/s Std Ele
Norge N3520SRA Range - F/s Std Ele
Norge N3520SRW Range - F/s Std Ele
Norge N3521XPA Range - F/s Std Ele
Norge N3521XPW Range - F/s Std Ele
Norge N3521XRA Range - F/s Std Ele
Norge N3521XRW Range - F/s Std Ele
Norge N3832XRA Range - S/c F/s Ele
Norge N3832XRW Range - S/c F/s Ele
Norge N3875XRA Range - S/c F/s Ele
Norge N3875XRW Range - S/c F/s Ele
Norge N3878VRV Range - S/c F/s Ele
Norge N3878VVD Range - S/c F/s Ele
Norge N3878VVV Range - S/c F/s Ele
Norge N3878XRA Range - S/c F/s Ele
Norge N3878XRW Range - S/c F/s Ele
Norge N3878XVA Range - S/c F/s Ele
Norge N3878XVW Range - S/c F/s Ele
Magic Chef N40C-3-X9 Mwave - Cntrtp / Stand Alone
Norge N4231WRA Range - F/s Cont Clean Gas
Norge N4231WRW Range - F/s Cont Clean Gas
Norge N4251WTA Range - F/s Std Gas
Norge N4251WTW Range - F/s Std Gas
Whirlpool N9157L0
Whirlpool N9157L1
Whirlpool N9157X0
Whirlpool N9157^0
Whirlpool N9157^1
Whirlpool N9257L1
Whirlpool N9257L2
Whirlpool N9257X0
Whirlpool N9257X1
Whirlpool N9257^0
Whirlpool N9257^1
Whirlpool N9257^2
Whirlpool N9357L0
Whirlpool N9357L2
Whirlpool N9357L3
Whirlpool N9357^0
Whirlpool N9357^2
Whirlpool N9357^3
Whirlpool N9457L3
Whirlpool N9457X0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrost problem joe shurites Refrigerator & Freezer Repair 1 09-13-2011 06:10 AM
Defrost Problem pasinir Refrigerator & Freezer Repair 3 11-02-2010 10:14 AM
defrost problem geno630 Refrigerator & Freezer Repair 0 02-14-2010 11:11 AM
defrost problem Judy2857 Refrigerator & Freezer Repair 1 12-11-2008 11:10 AM
GE Defrost problem (Defrost heater fuses ?) rkpatt Refrigerator & Freezer Repair 0 08-03-2008 05:24 AM
