| » Compressor starts when cool, not when haot |
Model Number: jfc2089htw Brand: Jenn-Air Age: 5 - 10 years
My french door fridge stopped cooling. When the compressor itself is allowed to cool, it will start and cool the fridge to specified temps and shut off, as it should. Later, when the warm/hot compressor tries to come on again, the relay buzzes, and the compressor will not start. If unplugged and allowed to cool again, the compressor will start.... I have replaced the relay unit - no change. I know the compressor failing is the likely trouble, any other possible causes for a short-cycling compressor? Is it possible the compressor is being asked to come on too frequently? What would cause that? The defrost circuit tests OK (all the tests when the unit is in service mode look OK). I'm hoping because the compressor runs, it's something else causing the problem. Am I dreaming? What to test next?
Hi.
Most likely the start winding in the compressor is damaged and fails when it's hot. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
As I said possibly the start winding fails when it's hot.
Simple ohming may not be enough to determine it. If the current draw is grater then listed on the compressor then it's bad. Simon.
__________________
When cool the compressor starts every time and takes the fridge/freezer to operating temps (38 and 0), which, after reading your post, I confirmed with a second thermometer and not just with the fridge’s own display. It’s restarting to maintain the temps where the problem arises. Today I noted when the fridge/freezer reached the proper temperatures and listened for the compressor to shut off. It shut off about 30 minutes after the freezer digital temp was 0 and right about exactly when the secondary thermometer reached zero. 15 minutes later, without ever opening a door, the compressor tried to come on again, the relay buzzed and the compressor did not start. About 60-90 seconds later it tried again. And 60-90 seconds again.... Then I shut if off. It seems like the compressor is being asked to come on too soon/often. We have frequent power interruptions in my area, could this have taken a toll on the main board (I see no physical damage on it)?
The compressor doesn’t cool enough to start before being asked to come on again. Frustrating. |
It is possible the compressor is overheating due to low refrigerant. Gauges and amprobe would confirm. If the compressor seems to be running longer than normal, that would confirm it.
If you cool the compressor with a portable fan and it no longer fails to start, that would confirm low refrigerant, or a bad compressor/clogged condenser. A partially clogged capillary would do the same thing, but the compressor current would be lower than normal.
__________________
No, not at all. The control module controls the hysteresis ( differential between turn off/ turn on temperature levels).
Also, it is possible the thermistor is cracked and off value. I would replace both.
__________________
| Display Modes | |
| Compressor starts and stops after few seconds | dragonfff | Refrigerator & Freezer Repair | 3 | 05-18-2012 01:11 AM |
| Tap on thermostat and starts to cool | Tlegband | Refrigerator & Freezer Repair | 1 | 01-16-2011 01:18 AM |
| dryer starts cool down too soon | ctcashatt | Dryer Repair | 1 | 10-27-2010 05:33 PM |
| Kelvinator compressor starts then stops | tag159 | Refrigerator & Freezer Repair | 4 | 10-05-2010 09:08 AM |
| Compressor starts up and quits | ldsallee | Refrigerator & Freezer Repair | 1 | 08-31-2010 02:25 PM |
