Discuss
Compressor starts when cool, not when haot
 in
Refrigerator & Freezer Repair
I been trying to justify replacing the main board as a last-ditch effort, I'll try it. The freezer and fridge
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor starts when cool, not when haot
  #11 (permalink)
Old 10-06-2012, 07:28 AM
Junior Member
c893 is on a distinguished road
Default
I been trying to justify replacing the main board as a last-ditch effort, I'll try it. The freezer and fridge thermistor both reported accurate temperatures in the service mode checks. Here is another symptom: This first happened a month ago. I looked for bad electrical connections, replaced the start relay and even the freezer thermostat. The unit started up and ran fine for 3 weeks. I suspected at the time that I hadn't really "fixed" anything, that the mere passage of time might have had more to do with the refrigerator resuming normal operation than anything I did. So does it say anything that after the unit was off for 4 or 5 days it was able to resume functioning for a few weeks? Does that help confirm any of your other diagnoses?
Ads By Google
  #12 (permalink)
Old 10-06-2012, 03:05 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
It confirms my suspicion you may have a cracked thermistor. Control modules generally do not become intermittent in this way, but thermisters do.
__________________
  #13 (permalink)
Old 10-07-2012, 09:09 AM
Junior Member
Default
Well, that is an easier fix. My unit has freezer and fridge thermistors: are both suspect or just the one in the freezer? Thanks for your continued help.
  #14 (permalink)
Old 10-08-2012, 01:44 AM
Senior Expert
APP Volunteer
Default
It is also possible there is a bad connection to the compressor when it gets warm. Get a meter and monitor the compressor voltage. When it is cold, voltage to it should be 115 volts, when hot, should be the same when it tries to start.
__________________
  #15 (permalink)
Old 10-10-2012, 01:35 PM
Junior Member
Default
Replaced both thermistors. Unit cooled to proper temps, shut off, then 10 minutes later the compressor began its regular routine of trying to start (relay buzzing) stopping for a couple of minutes, and trying again, and so on. Here is a new and curious symptom: After the compressor tried and failed to start a few times I turned off the unit, unplugged the wiring harness to the relay, turned the unit back on with a volt meter on the harness to see if it was still getting 120v (all OK) turned the unit off, plugged the harness back in, turned the unit on, compressor started right up EVEN THOUGH HOT!? With the volt meter in place I had jiggled every wire in sight trying to see if I could get a voltage drop, nothing, a nice steady 120, so I don’t think that I inadvertently made a better connection when reattaching the harness. A lose connection is something I looked for right from the start, and wiggling the wiring harness to the relay, pressing in on it, etc.,, when the compressor was trying to start all had no effect.
I went the through a similar routine a second time when the compressor failed to start hot, omitting only the attaching of the voltmeter: turned the unit off, disconnected harness to relay, turned the unit on, turned it off again, attached harness, turned unit on: hot compressor started up. VERY strange to me, any help to you?
  #16 (permalink)
Old 10-10-2012, 02:11 PM
Junior Member
Default
Follow up: When the compressor failed to restart again after cooling the freezer/fridge to proper temps, I went through the above routine again with no effect: hot compressor did not start. I'm baffled....
  #17 (permalink)
Old 10-11-2012, 01:46 AM
Senior Expert
APP Volunteer
Default
You probably have a compressor drawing excessive current. I would get an amprobe and check.
__________________
  #18 (permalink)
Old 10-11-2012, 11:12 AM
Junior Member
Default
I only have a very cheap and likely inaccurate amp meter. But when the compressor successfully started it seemed to draw about 9.5 amps, and when it failed to start (i.e., while the relay was buzzing) the meter peaked about 7.3-4 amps.
  #19 (permalink)
Old 10-12-2012, 01:13 AM
Senior Expert
APP Volunteer
Default
Monitor the compressor input voltage and note the voltage when it fails to start.
__________________
  #20 (permalink)
Old 10-12-2012, 01:36 PM
Junior Member
Default
My meter reads 123v with the compressor off, but it drops to 118-19 when it tries to start.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compressor starts and stops after few seconds dragonfff Refrigerator & Freezer Repair 3 05-18-2012 01:11 AM
Tap on thermostat and starts to cool Tlegband Refrigerator & Freezer Repair 1 01-16-2011 01:18 AM
dryer starts cool down too soon ctcashatt Dryer Repair 1 10-27-2010 05:33 PM
Kelvinator compressor starts then stops tag159 Refrigerator & Freezer Repair 4 10-05-2010 09:08 AM
Compressor starts up and quits ldsallee Refrigerator & Freezer Repair 1 08-31-2010 02:25 PM
