Discuss
PART #12002782 defective? ORDER#296178
 in
Refrigerator & Freezer Repair
I JUST GOT THIS PART. THE INSTRUCTIONS SAY TO INSTALL WHITE JUMPER WIRE IN #1 TERMINAL ON RELAY(UPPER LEFT
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » PART #12002782 defective? ORDER#296178
  #1 (permalink)
Old 01-30-2008, 03:52 PM
dj1 dj1 is offline
Junior Member
dj1 is on a distinguished road
Default PART #12002782 defective? ORDER#296178
Model Number: PTB1949GRW   Brand: Maytag   Age: 5 - 10 years
I JUST GOT THIS PART. THE INSTRUCTIONS SAY TO INSTALL WHITE JUMPER WIRE IN #1 TERMINAL ON RELAY(UPPER LEFT ON RELAY). #1 ON RELAY DOESN'T HAVE COPPER TERMINAL PROTRUDING OUT TO ATTACH WHITE WIRE. ACCORDING TO THE WIRING ON THE OLD PART IT LOOKS LIKE IT SHOULD GO ON TERMINAL #2(LOWER LEFT ON RELAY). COULD THE INSTRUCTIONS BE WRONG?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-31-2008, 02:16 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If you can post a pictures of the old and the new parts and the installation instructions as well - it might help better. So far I do not see any difference.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-01-2008, 09:54 AM
dj1 dj1 is offline
Junior Member
Default
i already installed the parts. i put the white jumper wire on the left lower terminal of the relay, which was the most logical place for it to go. the picture on the instructions isn't that clear but it seems to correspond. the only real problem is the instructions say its marked #1 when it actually is marked#2. at any rate...after 2 days everything is working perfect so i guess i got lucky. thanks for your help. dj
  #4 (permalink)
Old 02-01-2008, 10:28 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Still looking for the name of the part I need to order Melrose Dryer Repair 0 01-21-2008 10:43 PM
Which ice maker water valve to order? blazindaily Refrigerator & Freezer Repair 12 01-17-2008 06:08 PM
Freezer part cold, fridge part warm keithpar Refrigerator & Freezer Repair 1 10-08-2007 04:21 AM
Defective Coils (Dryer) Melindat28 Dryer Repair 5 09-21-2007 07:05 AM
what part do i need? agitator Washer Repair 1 07-27-2007 05:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
