Discuss
Maytag side by side fridge not cooling
 in
Refrigerator & Freezer Repair
We have a Maytag side by side, model MSD2735GR. While I wish I could justify getting rid of it (I've
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag side by side fridge not cooling
  #1 (permalink)
Old 10-01-2012, 02:59 PM
Junior Member
Klayfish is on a distinguished road
Default Maytag side by side fridge not cooling
Brand: Maytag   Age: 5 - 10 years
We have a Maytag side by side, model MSD2735GR. While I wish I could justify getting rid of it (I've never been a huge fan of it), we need it to last several more years.
We noticed last night the fridge didn't seem as cool as it usually is. This morning, there was no doubt about it. The fridge isn't cold. The freezer seems to be working fine. Everything is frozen in it, there's no frost on the walls, etc...
I know the fridge pulls its' cold air from the freezer. If I'm right, the thing between the fridge/freezer is a diffuser? Is that likely the problem? Could something just be frozen/stuck?
Ads By Google
  #2 (permalink)
Old 10-01-2012, 06:54 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
First check if the evaporator fan is running.
Then open the freezer door and check if the air is going through the air damper into the refrigerator (up at the top).
If the air blows with the door open and doesn't with door closed - there is the defrost system problem.
Open the rear panel in the freezer and check if the evaporator coils are blocked with snow.
There are 3 things in the defrost system: defrost timer, defrost thermostat and defrost heater.
Locate in the refrigerator top right, rear the defrost timer's shaft.
Use the flat screw driver to slowly turn it CW until the fridge stops.
In 5 minutes check if the defrost heater is on.
If it is - replace the timer Part number: 68233-2
If not- check the thermostat and heater for continuity.
The thermostat must be ice cold when tested.
The thermostat and heater asm Part number: 61006197
Here are the breakdown diagrams and Replacement parts for Maytag MSD2735GRW REF - SXS/I&W | AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE side by side fridge/freezer not cooling or freezing Lou7 Refrigerator & Freezer Repair 2 04-24-2012 09:46 AM
Fridge not cooling on side by side unit cowboybravesfan Refrigerator & Freezer Repair 0 10-07-2011 01:24 PM
GE side by side fridge made grinding noise in freezer then stopped cooling properly 4belmont Refrigerator & Freezer Repair 0 09-10-2011 07:44 AM
kenmore side by side fridge/freezer not freezing or cooling tspires Refrigerator & Freezer Repair 4 10-24-2010 09:12 AM
Side by Side fridge and freezer not cooling and making no ice! krm208 Refrigerator & Freezer Repair 1 07-11-2008 06:41 PM
