| » No Ice |
Model Number: FRS23LH5DS0 Brand: Frigidaire Age: 5 - 10 years
The ice maker on my frigidare side-by-side is not making ice. I am still getting water at the water dispenser and if I pour water into the tray manually it will eject icecubes in the normal time. I think the water valve may be bad, although it is still suppling water to the water dispenser. is there a reset switch?
Swap the wires between the ice maker and the water dispenser solenoids at the water inlet valve. Push the water dispenser lever for a few seconds and check for water in the ice maker.
If there is no water, replace the water valve. If there is water, replace the ice maker. - The water valve Part number: 241734302 - The ice maker Part number: 5304458371 Here are the breakdown diagrams and Replacement parts for Frigidaire FRS23LH5DS0 Frigidaire/refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
Re: frigidare FRS23LH5DS0 side-by-side.
I replaced the water valve and the Icemaker - Still no ice? I have water to the back of the icemaker, but it is not filling the tray when I rotate the paddles to 7:00 o clock postion. What now? |
Have you checked the water tube into the ice maker for any blockage and/or ice inside?
__________________
Yes, I checked the water tube up to the point where it enters the back of the refrigerator behind the freezer, and I defrosted the freezer to allow any ice inside time to melt (about and hour). Do you think it needs more time to thaw?
I would disconnect the ice maker tube (1/4") from the water valve and blow some air through the tube.
__________________
| Display Modes | |
