Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   stopped cooling (http://forum.appliancepartspros.com/refrigerator-freezer-repair/501453-stopped-cooling.html)
amcolema 09-28-2012 08:57 PM
stopped cooling
On Wednesday the appliance repair man came and replaced starter relay using relay overload start compacitor combo 3n'1 start. Cut some wires and put this in and worked until today. When he left everything was running. This evening the fridge got quiet the only thing running is the fan inside the freezer. Compressor and fan in the back underneath is not working. Wednesday spent $200 on appliance repair man. Would like to try fixing this myself this time. Thanks for any and all help.
richappy 09-29-2012 02:19 AM
I have stated before on this site,NEVER use a 3n1 hard start kit on a modern R134A compressor. The first power surge will cause the kit to send excessive current to the compressor through the adaptive defrost board AP4909015 probably blowing out both items.
You will probably find the compressor start winding is blown open along with the adaptive defrost board.
This evidence and warning has been published for many years, apparently your service person is just not informed of this, so I would try to get your money back.
amcolema 09-29-2012 11:46 AM
Thank you so much, He is coming back out on Monday. I wish I would have found this site before I had him come out!!
amcolema 09-29-2012 11:56 AM
AP4909015 is a Adc Iv Kit
richappy 09-30-2012 02:50 AM
Get an ohmeter and test continuty across the three compressor pins, you might find one blown open. Usually the common pin is at the top, and run and start pins on the bottom.
amcolema 10-04-2012 07:12 PM
AP4503415; this is from this site.. Would you use one of these?
How can you tell if the compressor is out? He came back on Monday and will be back tomorrow to replace the part he replaced on last week with the part he should have used in the first place. He also told me that the defrost board is not working. What should I say to him?
richappy 10-05-2012 01:49 AM
If you have no meter, I would get someone else to look at it. As I stated,your compressor may be blown.
amcolema 10-06-2012 11:09 AM
board blew again compressor out
Just replaced the relay[part] 5304468029 MFG withPart number: AP4367355
, also replaced original defrost board withPart number: AP4909015
Adc IV kit. The board blew again. I took both board apart and looks like they both blew at the compressor out.
richappy 10-06-2012 03:00 PM
If you get a ohmeter, test the compressor terminals to ground, probably shorted to ground.
