Discuss
under ice box and under ice tray gets ice Cycles
 in
Refrigerator & Freezer Repair
NEW POST Thank you for your Reply, but the ice tray is not leaking. After drying everything out it will
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » under ice box and under ice tray gets ice Cycles
  #1 (permalink)
Old 09-27-2012, 11:21 PM
Junior Member
jaynoll80 is on a distinguished road
Default under ice box and under ice tray gets ice Cycles
Model Number: pss29ngmbcc   Brand: GE   Age: 5 - 10 years
NEW POST
Thank you for your Reply, but the ice tray is not leaking. After drying everything out it will not have any ice Cycles for about 2 weeks then 1/2 inch long ice Cycles will start to form hanging under the back of the plastic ice box holding all the ice cubes and under the white medal box with the ice motor and stuff inside of it. The problem is that it finally freezes up the ice and chip motor that goes up and down. When you try to get ice in a glass it just gives you chips. If I take the ice motor box apart, everything in it is rock hard iced up.The ice auger will still turn to get ice out but the cube and chip motor freezes and won’t go up or down. I have no leaky seal problem. It’s like the evaporator heater comes on too long. I timed it and it was on for about 25 minute’s way after all the ice was gone on the coils. Replacing the thermostat limiter timer did not help. Therefore, if the heater stays on to long it can start to melt the ice cubes in the box and tray. I have bought a new control panel for the back. I had already replaced it before 4 years ago due to the refrigerate not cooling. As far as water pressure, I have tried different pressures and it makes no difference. I have looked for any kind of water leak from the ice filler for days, there is none. Let’s see if the control panel works. It is not the thermal misters either.
OLD POST
Back of icemaker freezes up and freezes the icemaker crusher dispenser motor that makes cubes or crushed ice. I have replaced the Defrost limiter thermostat but it came right back. After defrosting the freezer within 2 weeks little ice cycles will form under the back motor cover and under the icebox and then the crusher dispenser motor will freeze up and won’t go up and down. I thought maybe the water coming into the ice tray could be leaking but its not. Could it be that the defrost heater warms up the ice tray and the evaporator fan is not working properly to circulate the air and dry things up before they freeze up again. In about about 2 months I will take the icemaker crusher dispenser motor apart and it is a solid block of ice, where could the water be coming from that makes it all freeze up. The ice tray sits right over this but it is not leaking or is it splashing when filling. When the ice tray is full of ice cubes can the defrost comes on and make condensation under the tray and make it drip before it freezes back up. Is this a sign of a bad evaporator fan? I am now trying a ½ inch insulation board right under the ice tray to shield it from heat when the defrost is on. Everything else works just fine. Freezer stays 0 degrees, fridge stays cold, defrost heater does not build up ice. I replaced the back control module 3 years ago, that is in the back.
Ads By Google
Related Models
General Electric PSS29NGMBCC Refrigerator
General Electric PSS29NGMBWW Refrigerator
General Electric PSS29NGMCBB Refrigerator
General Electric PSS29NGMCCC Refrigerator
General Electric PSS29NGMCWW Refrigerator
General Electric PSS29NGMDBB Refrigerator
General Electric PSS29NGMDCC Refrigerator
General Electric PSS29NGMDWW Refrigerator
General Electric PSS29NGNABB Refrigerator
General Electric PSS29NGNACC Refrigerator
General Electric PSS29NGNAWW Refrigerator
General Electric PSS29NGPABB Refrigerator
General Electric PSS29NGPACC Refrigerator
General Electric PSS29NGPAWW Refrigerator
General Electric PSS29NGPBBB Refrigerator
General Electric PSS29NGPBCC Refrigerator
General Electric PSS29NGPBWW Refrigerator
General Electric PSS29NGPCBB Refrigerator
General Electric PSS29NGPCCC Refrigerator
General Electric PSS29NGPCWW Refrigerator
General Electric PSS29NGSABB Refrigerator
General Electric PSS29NGSACC Refrigerator
General Electric PSS29NGSAWW Refrigerator
General Electric PSS29NGSBBB Refrigerator
General Electric PSS29NGSBCC Refrigerator
General Electric PSS29NGSBWW Refrigerator
General Electric PSS29NHMABB Refrigerator
General Electric PSS29NHMACC Refrigerator
General Electric PSS29NHMAWW Refrigerator
General Electric PSS29NHMBBB Refrigerator
General Electric PSS29NHMBCC Refrigerator
General Electric PSS29NHMBWW Refrigerator
General Electric PSS29NHMCBB Refrigerator
General Electric PSS29NHMCCC Refrigerator
General Electric PSS29NHMCWW Refrigerator
General Electric PSS29NHMDBB Refrigerator
General Electric PSS29NHMDCC Refrigerator
General Electric PSS29NHMDWW Refrigerator
General Electric PSS29NHNABB Refrigerator
General Electric PSS29NHNACC Refrigerator
General Electric PSS29NHNAWW Refrigerator
General Electric PSS29NHPABB Refrigerator
General Electric PSS29NHPACC Refrigerator
General Electric PSS29NHPAWW Refrigerator
General Electric PSS29NHPBBB Refrigerator
General Electric PSS29NHPBCC Refrigerator
General Electric PSS29NHPBWW Refrigerator
General Electric PSS29NHPCBB Refrigerator
General Electric PSS29NHPCCC Refrigerator
General Electric PSS29NHPCWW Refrigerator
General Electric PSS29NHSABB Refrigerator
General Electric PSS29NHSACC Refrigerator
General Electric PSS29NHSAWW Refrigerator
General Electric PSS29NHSBBB Refrigerator
General Electric PSS29NHSBCC Refrigerator
General Electric PSS29NHSBWW Refrigerator
General Electric PSS29NSTASS Refrigerator
General Electric PSS29NSTESS Refrigerator
General Electric PST26NGPABB Refrigerator
General Electric PST26NGPACC Refrigerator
General Electric PST26NGPAWW Refrigerator
General Electric PST26NGPBBB Refrigerator
General Electric PST26NGPBCC Refrigerator
General Electric PST26NGPBWW Refrigerator
General Electric PST26NGPCBB Refrigerator
General Electric PST26NGPCCC Refrigerator
General Electric PST26NGPCWW Refrigerator
General Electric PST26NGPDBB Refrigerator
General Electric PST26NGPDCC Refrigerator
General Electric PST26NGPDWW Refrigerator
General Electric PST26NGPEBB Refrigerator
General Electric PST26NGPECC Refrigerator
General Electric PST26NGPEWW Refrigerator
General Electric PST26SGPASS Refrigerator
General Electric PST26SGPBSS Refrigerator
General Electric PST26SGRCSS Refrigerator
General Electric PST26SGRDSS Refrigerator
General Electric PST26SGRESS Refrigerator
General Electric PST26SHPASS Refrigerator
General Electric PST26SHPBSS Refrigerator
General Electric PST26SHRCSS Refrigerator
General Electric PST26SHRDSS Refrigerator
General Electric PST26SHRESS Refrigerator
General Electric PST27SGPBSS Refrigerator
General Electric PST27SGRCSS Refrigerator
General Electric PST27SGRDSS Refrigerator
General Electric PST27SGRESS Refrigerator
General Electric PST29NHPBBB Refrigerator
General Electric PST29NHPBCC Refrigerator
General Electric PST29NHPBWW Refrigerator
General Electric PST29NHPCBB Refrigerator
General Electric PST29NHPCCC Refrigerator
General Electric PST29NHPCWW Refrigerator
General Electric PSW23PSRASS Refrigerator
General Electric PSW23PSRBKSS Refrigerator
General Electric PSW23PSRCKSS Refrigerator
General Electric PSW23PSSAKSS Refrigerator
General Electric PSW23PSSBKSS Refrigerator
General Electric PSW23PSSCSS Refrigerator
General Electric PSW23PSTASS Refrigerator
General Electric PSW23PSTBSS Refrigerator
General Electric PSW26LSRDSS Refrigerator
General Electric PSW26LSRESS Refrigerator
General Electric PSW26MSRBSS Refrigerator
General Electric PSW26MSRCKSS Refrigerator
General Electric PSW26MSRDSS Refrigerator
General Electric PSW26MSRESS Refrigerator
General Electric PSW26MSTA SS
General Electric PSW26MSTBSS Refrigerator
General Electric PSW26MSTDSS Refrigerator
General Electric PSW26MSTESS Refrigerator
General Electric PSW26PSSAKSS Refrigerator
General Electric PSW26PSSBSS Refrigerator
General Electric PSW26PSSCSS Refrigerator
General Electric PSW26PSSDSS Refrigerator
General Electric PSW26PSTASS Refrigerator
General Electric PSW26PSTBSS Refrigerator
General Electric PSW26SGNABS Refrigerator
General Electric PSW26SGPASS Refrigerator
General Electric PSW26SGRASS Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water misses ice tray and lands in holding tray yramkirk Refrigerator & Freezer Repair 0 08-03-2012 09:50 PM
spins 3 cycles one way, 3 cycles the other way, then will not spin after that huntly Washer Repair 2 09-26-2011 04:10 AM
Ice Tray zman67 Refrigerator & Freezer Repair 0 06-03-2011 06:59 AM
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
ice tray kenneth-archibald@sbcglob Refrigerator & Freezer Repair 1 10-16-2008 01:45 PM
