Discuss
Ice maker fill tube dripping
 in
Refrigerator & Freezer Repair
I have a LG LRSC26923TT and have had it for 3 years. Starting about 6 months ago, it occasionally would
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker fill tube dripping
  #1 (permalink)
Old 09-23-2009, 03:24 PM
Junior Member
heathk is on a distinguished road
Default Ice maker fill tube dripping
Model Number: LG LRSC26923TT   Brand: -other-   Age: 1 - 5 years
I have a LG LRSC26923TT and have had it for 3 years. Starting about 6 months ago, it occasionally would spray water inside the freezer as it attempted to fill the tray. Then the water dispenser quit working. The freezer fill tube was completely frozen so I defrosted the whole thing for about 18 hours. Long story boring, the water still didn't work so I replaced the water valve in the back (the main valve was corroded). Now the water dispenser works great, but the ice maker fill tube is still dripping causing ice to build up in it. To top it off, the ice cube tray seems to have gotten stuck in the half-empty spot.
1.) What can I do to make the fill tube stop dripping and freezing?
2.) Is there a way to troubleshoot the ice maker part to see what's wrong with it?
Thanks in advance.
Ads By Google
Related Models
Amana LG1009W Dryer - Gas
Amana LG1101 Dryer - Gas
Amana LG1112 Washer - Top Loading
Whirlpool LG2001XSW0
Amana LG2112L Dryer - Gas
Amana LG2112W Dryer - Gas
Amana LG2401 Dryer - Gas
Amana LG2412 Dryer - Gas
Amana LG2501 Dryer - Gas
Amana LG2512 Dryer - Gas
Amana LG2811 Dryer - Gas
Amana LG2812 Dryer - Gas
Amana LG2902 Washer - Top Loading
Amana LG2911 Dryer - Gas
Amana LG2912 Dryer - Gas
Whirlpool LG3001XKW0
Whirlpool LG3001XMW0
Whirlpool LG3001XMW1
Whirlpool LG3001XMW2
Whirlpool LG3001XPW0
Whirlpool LG3001XSW0
Whirlpool LG3006XPW0
Amana LG3412G Dryer - Gas
Amana LG3412L Dryer - Gas
Amana LG3412W Dryer - Gas
Amana LG3512L Dryer - Gas
Amana LG3512W Dryer - Gas
Amana LG3812L Dryer - Gas
Amana LG3812W Dryer - Gas
Amana LG3912L Dryer - Gas
Amana LG3912W Dryer - Gas
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L Dryer - Gas
Amana LG4209L2 Dryer - Gas
Amana LG4209W Dryer - Gas
Amana LG4209W2 Dryer - Gas
Amana LG4219L2 Dryer - Gas
Amana LG4219W2 Dryer - Gas
Amana LG4309L Dryer - Gas
Amana LG4309W Dryer - Gas
Amana LG4319L2 Dryer - Gas
Amana LG4319W2 Dryer - Gas
Amana LG4409L Dryer - Gas
Amana LG4409W Dryer - Gas
Amana LG4429L Dryer - Gas
Amana LG4429W Dryer - Gas
Whirlpool LG4441XWW0
Whirlpool LG4441XWW1
Amana LG4509L Dryer - Gas
Amana LG4509W Dryer - Gas
Amana LG4609L Dryer - Gas
Amana LG4609W Dryer - Gas
Amana LG4809L Dryer - Gas
Amana LG4809W Dryer - Gas
Amana LG4909L Dryer - Gas
Amana LG4909W Dryer - Gas
Whirlpool LG4931XMW0
Whirlpool LG4931XSW0
Whirlpool LG4931XTF0
Whirlpool LG4931XTG0
Whirlpool LG4931XTM0
Whirlpool LG4931XTN0
Whirlpool LG4931XTN1
Whirlpool LG4931XTW0
Whirlpool LG4931XTW1
Whirlpool LG4931XTW2
Whirlpool LG4936XMW0
Whirlpool LG4936XMW1
Whirlpool LG5201XTF0
Whirlpool LG5201XTG0
Whirlpool LG5201XTM0
Whirlpool LG5201XTN0
Whirlpool LG5201XTN1
Whirlpool LG5201XTW0
Whirlpool LG5201XTW1
Whirlpool LG5321XTF0
Whirlpool LG5321XTG0
Whirlpool LG5321XTM0
Whirlpool LG5321XTN0
Whirlpool LG5321XTW0
Whirlpool LG5531XKW0
Whirlpool LG5531XKW1
Whirlpool LG5531XMG2
Whirlpool LG5531XMN2
Whirlpool LG5531XMW0
Whirlpool LG5531XMW1
Whirlpool LG5531XMW2
Whirlpool LG5531XPW0
Whirlpool LG5531XSW0
Whirlpool LG5531XSW1
Whirlpool LG5536XPW0
Whirlpool LG5551XTG0
Whirlpool LG5551XTN0
Whirlpool LG5551XTW0
Whirlpool LG5601XKW0
Whirlpool LG5601XMW0
Whirlpool LG5601XPW0
Whirlpool LG5601XSW0
Whirlpool LG5601XSW1
Whirlpool LG5606XPW0
Whirlpool LG5651XKW0
Whirlpool LG5651XKW1
Whirlpool LG5651XMW0
Whirlpool LG5651XMW1
  #2 (permalink)
Old 09-23-2009, 06:13 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
An ice cube will jam occaissionally. Use a hair dryer to melt the ice cube until the ice maker starts to move.
  #3 (permalink)
Old 09-23-2009, 07:22 PM
Senior Member
applianceman is on a distinguished road
Default
The water valve is causing the fill tube to clog with ice. Remove the ice out of the fill tube and replace the water valve. Hope this helps!! Refrigerator repair guide
  #4 (permalink)
Old 09-23-2009, 07:27 PM
Junior Member
Default
Quote:
The water valve has already been replaced just a few days ago. Any other ideas?
  #5 (permalink)
Old 09-23-2009, 07:30 PM
Junior Member
Default
Quote:
I didn't see any ice blocking it. Is it possible that the gear is going bad?
  #6 (permalink)
Old 09-23-2009, 07:38 PM
Senior Member
Default
Cut the icemaker off and remove the line from the back tube and watch it. Does water drip out the line?
  #7 (permalink)
Old 09-23-2009, 08:02 PM
Junior Member
Default
I'm not sure what you mean by 'cut the icemaker off'. Are you saying pull the line from the back of the refridgerator at the top where it goes into the freezer? If that's what you're asking and if it does still leak, did I get a bad valve that was doing the exact same thing my orginal valve did after 3 years, or is there something else?
Thanks.
  #8 (permalink)
Old 09-23-2009, 08:07 PM
Senior Member
Default
Yes that is what I mean. I only told you to cut the icemaker off just in case it called for water while you had the line off.
I can’t see it being anything other than the water valve if water drips from the line but I couldn’t look your model number up on this site. I will try another site to see if can find a parts breakdown so that I can see if I am missing something.
  #9 (permalink)
Old 09-23-2009, 08:17 PM
Senior Member
Default
I did find a parts breakdown but I still say water valve. Disconnect the wires from the water valve leaving the water on and if the water still drips you know for sure the valve is bad and if that stops it the icemaker is bad.
  #10 (permalink)
Old 09-24-2009, 04:52 AM
Junior Member
Default
If that's the case, that really sucks considering I just replaced the water valve on Saturday ($100). So, if the ice tray fill tube has small clumps of ice in it that gradually build over time and eventually block the line and spray water all over the freezer?
On a separate issue, I wonder if the occasional water missing the tray and splashing inside the freezer is from the ice cube tray not getting into position. Twice now I've opened the freezer to see the tray either all the upside down or partially. At first I thought I just caught it mid-cycle. But five minutes later it's still in that position. Checking an hour later it's back in the correct position.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker water splashes out of fill tube mharrison Refrigerator & Freezer Repair 2 07-06-2011 09:51 AM
ice maker fill tube frozen chip Refrigerator & Freezer Repair 1 06-15-2009 12:32 PM
Amana ice maker replacement fill tube billwh Refrigerator & Freezer Repair 2 03-12-2009 08:07 AM
Ice Maker Fill Tube? Keegan Refrigerator & Freezer Repair 1 02-13-2008 11:40 AM
ice maker fill tube freezing ricka Refrigerator & Freezer Repair 3 01-25-2008 06:07 AM
