| » Air in Water Line? |
Model Number: ASD2620HR Brand: Amana Age: 5 - 10 years
Back in May, I replaced the ice maker and water valve on the refrigerator. Everything was working fine until about six weeks ago, when I used the water dispenser. The water stream quickly went to a trickle with vibrating as if there was air in the line. Knowing it was about time to replace the water filter, I did that. Of course, there was more rattling as is normal with that replacement. But it has not gone away.
Water through the dispenser is still only a small stream. The ice maker still turns out ice ... and sometimes when filling is accompanied by vibration, sometimes not. Is there a stopped-up line or is it only air? I noticed that at the bottom from of the refrigerator behind the toe grille there is a connection. Is this a check valve of some sort? Is it a point at which to attempt something else? Thanks. Ads By Google Related Models |
| Display Modes | |
| Water line hgas a fizzure crack at based of freezer door. No water dispensed. | rkozak | Refrigerator & Freezer Repair | 0 | 11-29-2011 07:07 AM |
| Water line snapping and water only trickles, no or hollow ice | ladyred1101 | Refrigerator & Freezer Repair | 4 | 10-15-2010 07:08 AM |
| Freezer stopped working, electrical arc or odor, & leaking water from water/ice line | elmwood | Refrigerator & Freezer Repair | 1 | 10-10-2010 08:25 AM |
| Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water | ugagrad04 | Refrigerator & Freezer Repair | 0 | 07-20-2010 06:43 PM |
| Installing a Water Inlet Valve to copper water line | neilkrenz | Refrigerator & Freezer Repair | 0 | 09-27-2009 02:50 PM |
