Discuss
freezer fine refrigerator not cooling
 in
Refrigerator & Freezer Repair
I called a repairman and he said that the fan had fallen off of the evaporator motor. So he replaced
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer fine refrigerator not cooling
  #1 (permalink)
Old 09-23-2012, 03:37 PM
Junior Member
kleverts is on a distinguished road
Question freezer fine refrigerator not cooling
Model Number: ET1FHTXMQ04   Brand: Whirlpool   Age: 1 - 5 years
I called a repairman and he said that the fan had fallen off of the evaporator motor. So he replaced the fan, and said give it 24 hours and if it still didn't cool then he would have to replace the evaporator motor. Well it still doesn't cool, but the fan is running, so I don't understand why replacing the evaporator motor would fix my problem if the fan that is attached to the evaporator motor is running. Does the evaporator motor do something other than run the fan? Or do you think it could be something else?
Ads By Google
Related Models
Whirlpool ET1FHTXMQ04 Refrigerator
Whirlpool ET1FHTXMT00 Refrigerator
Whirlpool ET1FHTXMT01 Refrigerator
Whirlpool ET1FHTXMT02 Refrigerator
Whirlpool ET1FHTXMT03 Refrigerator
Whirlpool ET1FHTXMT04 Refrigerator
Whirlpool ET1FTEXLQ00
Whirlpool ET1FTEXLQ01
Whirlpool ET1FTEXLQ02 Refrigerator
Whirlpool ET1FTEXLT00
Whirlpool ET1FTEXLT01
Whirlpool ET1FTEXLT02 Refrigerator
Whirlpool ET1FTEXMQ00 Refrigerator
Whirlpool ET1FTEXMQ01 Refrigerator
Whirlpool ET1FTEXMQ02 Refrigerator
Whirlpool ET1FTEXMQ03 Refrigerator
Whirlpool ET1FTEXMT00 Refrigerator
Whirlpool ET1FTEXMT01 Refrigerator
Whirlpool ET1FTEXMT02 Refrigerator
Whirlpool ET1FTEXMT03 Refrigerator
Whirlpool ET1FTEXSQ00 Refrigerator
Whirlpool ET1FTEXST00 Refrigerator
Whirlpool ET1FTKXKQ00
Whirlpool ET1FTKXKQ01
Whirlpool ET1FTKXKQ02
Whirlpool ET1FTKXKQ03 Refrigerator
Whirlpool ET1FTKXKQ04 Refrigerator
Whirlpool ET1FTKXKQ05 Refrigerator
Whirlpool ET1FTKXKQ06 Refrigerator
Whirlpool ET1FTKXKQ07
Whirlpool ET1FTKXKQ09 Refrigerator
Whirlpool ET1FTKXKT00
Whirlpool ET1FTKXKT01
Whirlpool ET1FTKXKT02
Whirlpool ET1FTKXKT03 Refrigerator
Whirlpool ET1FTKXKT04 Refrigerator
Whirlpool ET1FTKXKT05 Refrigerator
Whirlpool ET1FTKXKT07
Whirlpool ET1FTTXKB01
Whirlpool ET1FTTXKB02
Whirlpool ET1FTTXKB03 Refrigerator
Whirlpool ET1FTTXKQ00
Whirlpool ET1FTTXKQ01
Whirlpool ET1FTTXKQ02
Whirlpool ET1FTTXKQ03 Refrigerator
Whirlpool ET1FTTXKT00
Whirlpool ET1FTTXKT01
Whirlpool ET1FTTXKT02
Whirlpool ET1FTTXKT03 Refrigerator
Whirlpool ET1GHMXPQ00 Refrigerator
Whirlpool ET1GHMXPT00 Refrigerator
Whirlpool ET1LFKXKB00
Whirlpool ET1LFKXKB01
Whirlpool ET1LFKXKB02 Refrigerator
Whirlpool ET1LFKXKB03 Refrigerator
Whirlpool ET1LFKXKB04 Refrigerator
Whirlpool ET1LFKXKB05 Refrigerator
Whirlpool ET1LFKXKB06 Refrigerator
Whirlpool ET1LFKXKB07 Refrigerator
Whirlpool ET1LFKXKB08 Refrigerator
Whirlpool ET1LFKXKQ00
Whirlpool ET1LFKXKQ01
Whirlpool ET1LFKXKQ02 Refrigerator
Whirlpool ET1LFKXKQ03 Refrigerator
Whirlpool ET1LFKXKQ04 Refrigerator
Whirlpool ET1LFKXKQ05 Refrigerator
Whirlpool ET1LFKXKQ06 Refrigerator
Whirlpool ET1LFKXKQ07 Refrigerator
Whirlpool ET1LFKXKQ08 Refrigerator
Whirlpool ET1LFKXKS02 Refrigerator
Whirlpool ET1LFKXKS03 Refrigerator
Whirlpool ET1LFKXKS04 Refrigerator
Whirlpool ET1LFKXKS05 Refrigerator
Whirlpool ET1LFKXKS06 Refrigerator
Whirlpool ET1LFKXKS07 Refrigerator
Whirlpool ET1LFKXKS08 Refrigerator
Whirlpool ET1LFKXKT00
Whirlpool ET1LFKXKT01
Whirlpool ET1LFKXKT02 Refrigerator
Whirlpool ET1LFKXKT03 Refrigerator
Whirlpool ET1LFKXKT04 Refrigerator
Whirlpool ET1LFKXKT05 Refrigerator
Whirlpool ET1LFKXKT06 Refrigerator
Whirlpool ET1LFKXKT07 Refrigerator
Whirlpool ET1LFKXKT08 Refrigerator
Whirlpool ET1MHEXRB00 Refrigerator
Whirlpool ET1MHEXRB01 Refrigerator
Whirlpool ET1MHEXRB02 Refrigerator
Whirlpool ET1MHEXRQ00 Refrigerator
Whirlpool ET1MHEXRQ01 Refrigerator
Whirlpool ET1MHEXRQ02 Refrigerator
Whirlpool ET1MHKXMB00 Refrigerator
Whirlpool ET1MHKXMB01 Refrigerator
Whirlpool ET1MHKXMB02 Refrigerator
Whirlpool ET1MHKXMB03 Refrigerator
Whirlpool ET1MHKXMB04 Refrigerator
Whirlpool ET1MHKXMB05 Refrigerator
Whirlpool ET1MHKXMB06 Refrigerator
Whirlpool ET1MHKXMQ00 Refrigerator
Whirlpool ET1MHKXMQ01 Refrigerator
Whirlpool ET1MHKXMQ02 Refrigerator
Whirlpool ET1MHKXMQ03 Refrigerator
Whirlpool ET1MHKXMQ04 Refrigerator
Whirlpool ET1MHKXMQ05 Refrigerator
Whirlpool ET1MHKXMQ06 Refrigerator
Whirlpool ET1MHKXMT00 Refrigerator
Whirlpool ET1MHKXMT01 Refrigerator
Whirlpool ET1MHKXMT02 Refrigerator
Whirlpool ET1MHKXMT03 Refrigerator
Whirlpool ET1MHKXMT04 Refrigerator
Whirlpool ET1MHKXMT05 Refrigerator
Whirlpool ET1MHKXMT06 Refrigerator
Whirlpool ET1MHMXRB00 Refrigerator
Whirlpool ET1MHMXRB01 Refrigerator
Whirlpool ET1MHMXRQ00 Refrigerator
Whirlpool ET1MHMXRQ01 Refrigerator
Whirlpool ET1MHMXRT00 Refrigerator
Whirlpool ET1MHMXRT01 Refrigerator
Whirlpool ET1MTEXLQ00
Whirlpool ET1MTEXLQ01
  #2 (permalink)
Old 09-23-2012, 04:21 PM
Junior Member
azkidane is on a distinguished road
Default refr not cooling
if the Refr not cooling and the eva fun working,it could be the dumper not air flow\\\, also make sur the bottom of the fresh food section must be open for air flow.
here is you can check first the diffrost terostat and elements are working proprly, 2nd the dumper are is open to flow air properly.
  #3 (permalink)
Old 09-24-2012, 03:29 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool ET1FHTXMQ04 REFRIGERATOR | AppliancePartsPros.com
If the fan blade is turning at the proper speed it should be OK.
No.
Probably but cannot be sure without being there.
You should be able to feel cold air entering the the top/back of the fresh food compartment. Take a look at section 4, Items 34, 20, 9 etc. are the mechanical linkage which open/close the damper. This regulates the amount of cold air entering the fresh food compartment. Check that the tech did not inadvertently leave it closed.
Are the compressor and fans cycling or are they on all the time.
If on all the time then you may have a defrost problem.
Check your freezer temperature. It should be 0 to 5 degrees F.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer not cooling/Refrigerator is fine gyoung345 Refrigerator & Freezer Repair 0 07-14-2012 06:43 AM
Refrigerator not cooling but freezer is fine carly Refrigerator & Freezer Repair 1 04-04-2012 12:55 PM
Freezer fine, Refrigerator not cooling MaBlack Refrigerator & Freezer Repair 3 07-21-2011 03:24 PM
Refrigerator not cooling freezer fine Lambert58 Refrigerator & Freezer Repair 9 03-21-2010 07:59 AM
Refrigerator not Cooling but Freezer Fine desertcafe@comcast.net Refrigerator & Freezer Repair 0 07-01-2009 03:08 PM
