Discuss
Jenn Air Refrig not cold in refer side
 in
Refrigerator & Freezer Repair
I have a Jenn Air frig Model JCD2389GES that is not cooling properly on the refer side. The Freezer section
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Jenn Air Refrig not cold in refer side
  #1 (permalink)
Old 08-13-2007, 11:25 AM
pwatts pwatts is offline
Junior Member
pwatts is on a distinguished road
Default Jenn Air Refrig not cold in refer side
Model Number: JCD2389GES   Brand: Jenn-Air   Age: 1 - 5 years
I have a Jenn Air frig Model JCD2389GES that is not cooling properly on the refer side. The Freezer section is good and cold. I had a fan inside the frig making a noise a few days ago but that went away.
Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-03-2007, 05:42 AM
sshein sshein is offline
Junior Member
sshein is on a distinguished road
Default Any answer??
Quote:
Any ideas?
We had the exact same thing happen to us about 2 weeks ago and now we are having that same cooling problem? What is the cause or issue?
Please advise.
Thank you!
  #3 (permalink)
Old 11-03-2007, 09:12 AM
Junior Member
Default
I had to change out the defrost sircuit bord. Mine was located in the top of the fridge side uder a shroud. Now it works fine. The relay in the board quit working and would not go itnot defrost mode. Also had to defrost my freezer side to get it cooling quicker. On my fridge you could not see the frost but had to tak everything out and remove the bakc wll covers. Sounds like a lot of work but really fairly simple to do. Good Luck.
  #4 (permalink)
Old 11-03-2007, 09:24 AM
Junior Member
Default
HI Pwatts, thank you.
Just a couple of questions...
How did you get that white shroad off? there are clips in the back but I don't want to brake it?
The defrost circuit board, is that the brass looking thing and what was the part number of the circuit board? easy to get?
Lastly,
DO I have to defrost the freezer to replace this curcuit board?
Thank you greatly!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side whirlpool water wont come out aduke Refrigerator & Freezer Repair 6 01-01-2008 05:40 PM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
Refer side not cooling properly, freezer okay lynbo11 Refrigerator & Freezer Repair 0 07-30-2007 08:02 AM
Side by Side freezer coil iceing over bksbjmds8 Refrigerator & Freezer Repair 2 07-25-2007 01:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
