Discuss
ice forming on bottom of fridge
 in
Refrigerator & Freezer Repair
My freezer keeps forming an ice,block at the bottom till it creeps out far enough to leak out on to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice forming on bottom of fridge
  #1 (permalink)
Old 09-19-2012, 02:22 PM
Junior Member
garrmp76 is on a distinguished road
Smile ice forming on bottom of fridge
Brand: Whirlpool   Age: 5 - 10 years
My freezer keeps forming an ice,block at the bottom till it creeps out far enough to leak out on to the floor and my ice maker is not working even after replacing the water valve
Ads By Google
  #2 (permalink)
Old 09-20-2012, 12:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-21-2012, 03:10 PM
Junior Member
Default
Quote:
Model # GS6SHAXMQ00. It is like there is water leaking from somewhere in the frezzer and freezes at the bottom
  #4 (permalink)
Old 09-21-2012, 07:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
One of the most common cause of the ice on the freezer floor is a blocked drain under the evaporator coils. Use a hair dryer to defrost it. Run some hot water through the drain using a turkey buster. Make sure the other end of the drain (at the back of the refrigerator) is not blocked either.
In regards of the ice maker problem check if the ice maker fill tube in the freezer ceiling is not blocked with ice.
__________________
  #5 (permalink)
Old 09-25-2012, 12:36 PM
Junior Member
Default
The drain was blocked , thanks . The water feed for the ice maker was not as far I can tell anyways. what would be my next step for trouble shooting the ice maker. It is not rotating through its cycle. Does that trigger the valve?
  #6 (permalink)
Old 09-25-2012, 12:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the freezer door. Make sure the on-off switch on the right side is on. Close the flipper door on the left side to open the optic beam from side to side and observe the LED on the right side. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool GS6SHAXMQ00 REFRIGERATOR | AppliancePartsPros.com
__________________
  #7 (permalink)
Old 09-25-2012, 07:17 PM
Junior Member
Default
I already checked , it is solid red when closed and blinks when the beam is blocked
  #8 (permalink)
Old 09-27-2012, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Perform the test as instructed in the attached file and post the results.
File Type: doc In door ice system - component diagnostics.doc (167.0 KB, 1 views)
__________________
  #9 (permalink)
Old 09-27-2012, 09:42 PM
Junior Member
Default
The plastic gear that turns the feeder was broken off. Can I replace that part or do I need A whole new ice maker. Thanks for all your help
  #10 (permalink)
Old 09-27-2012, 09:56 PM
Junior Member
Default
I went ahead and replaced the whole unit. I figure something had to cause the gear to break . You have been very helpful .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice forming in bottom of bottom mount freezer gordow Refrigerator & Freezer Repair 8 03-16-2013 02:48 PM
water forming on rear of fridge Flannthered Refrigerator & Freezer Repair 0 07-22-2012 01:38 PM
Amana Fridge:: Bottom freezer: Fridge freezing food jobol Refrigerator & Freezer Repair 3 08-05-2011 05:59 PM
Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Refrigerator & Freezer Repair 5 06-19-2009 04:51 AM
frost forming in bottom freezer compartment Betty Refrigerator & Freezer Repair 0 08-22-2007 06:48 AM
