| » water filter head/housing |
Model Number: MSD2651KGW Brand: Maytag Age: 5 - 10 years
I changed water filter about 30 days ago. Now when dispensing water (ice maker/dispenser is having no issues) fridge makes vibrating noise and water flow is s-l-o-w. So being the handy couple we try to be we replaced the dual water valve, 80 bucks later, nope not the right part. Problem remained unchanged. So I did what I should have done in the first place - removed the water filter. I put in the blue bypass cap and water dispensed fine again. I REMOVED BYPASS CAP. When I did I noticed water dripping from water filter head housing. If you're looking straight on at it, there is a blue circle and on the top and bottom of blue circle what looks like white screws. The water appears to be dripping from the white screw area. It has a pretty steady drip. So I am confused, does this mean housing is bad OR do these things have O rings that go bad and could cause this? Loving your site and hoping for help. Thanks!
Hi.
Based on the info you provided the filter housing should be replaced Part number: 67006524 Here are the breakdown diagrams and Replacement parts for Maytag MSD2651KGW REF - SXS/I&W | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Should not be any problems. Simon.
__________________
I ordered the water head filter housing from your website and while attempting the repair the water filter head housing, we broke the plate filter backing hinge and now needs it needs replaced. I see it on your site, it is as follows.
Item Number: AP4013990 Manufacturer's Number: 12688503 We have no idea how the one in our fridge comes off. Before I order the above referenced part from you, I want to make sure we are able to remove existing one. Do you have any instructions on removal of existing plate filter backing? Thank you. |
Hi.
This is very uncommon job. There is no instructions i could find. Use your common sense. Should be couple of screws holding it. Good luck. Post the results. Simon.
__________________
lucky us. there are no screws I used a mirror to look at that. only think i could think is that maybe it slides on a track. would you mind looking at the two pictures of the part on your website and see what you think.
finally, is there anywhere I can find the information on removing these. |
Hi.
Not sure, but looks like it just clips in. Get a new part and that should help to figure this out. Simon.
__________________
| Display Modes | |
| Need instructions for installing a new water filter housing head & water tubes | vr104 | Refrigerator & Freezer Repair | 0 | 04-17-2012 10:44 AM |
| Removing Water Filter Housing | jikwee | Refrigerator & Freezer Repair | 1 | 10-17-2011 05:57 AM |
| replacing Head water filter | jmyfry | Refrigerator & Freezer Repair | 4 | 04-29-2011 04:01 PM |
| Procedure for replacing water filter head? | mountcomp | Refrigerator & Freezer Repair | 1 | 03-12-2009 04:08 PM |
| water filter head assembly GE | fwjg180 | Refrigerator & Freezer Repair | 0 | 03-25-2008 10:10 AM |
