Discuss
Compressor not starting
 in
Refrigerator & Freezer Repair
I ordered an overload relay kit. The part received and the part present on the compressor are definitely different and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor not starting
  #1 (permalink)
Old 09-19-2012, 10:28 AM
Junior Member
clydeself is on a distinguished road
Default Compressor not starting
Model Number: 106.54383300   Brand: Kenmore   Age: More than 10 years
I ordered an overload relay kit. The part received and the part present on the compressor are definitely different and I have no instructions on how to use the "new design" from the manufacturer. However, I can figure out what goes where and how to wire it up. The capacitor actually plugs into the old piece and would have to be wired to the two terminal that connect to the round plugs that attach to the compressor on the new one. In other words I would have to make two new wires to make this connection. One of the power wires (white I think) goes to the black piece and the hot (red) will plug into the white piece AFTER the connector is cut off and new ends added to the power wires. Both the black and white piece plug onto the compressor with no problem. I have not installed the new pieces. (DISCLAIMER: This wiring has not been confirmed by a professional technician)
However, the old one piece unit measured 5 ohms and is not way blown like many of the pictures I have seen. I took it apart and examined it inside. I suspect the old one piece unit may be ok.
My parents are on a fixed income and we are unable to pay for a repair man to come and fix the fridge for them as they are (in regards to our budget) very expensive. Worth every penny, but out of our cost range.
Therefore, here is what I noticed this morning. . .
1. Plug in the unit
2. The compressor fan begins to turn slowly after about 5 seconds
3. A slight and faint hum comes from the compressor with NO vibration
4. After a few seconds a click and the hum stops
5. The compressor never gets hot or tries to hum again unless it is unplugged from the wall and plugged back in.
6. I unplugged the capacitor and the symptoms did not change at all when the unit was plugged in.
I measured the compressor again. The terminals are in a Triangle and looks to be upside down. The top two are side beside each other with the one on the bottom by itself.
1. across the top two pins it is 9 ohms
2. from the bottom to the top right is 5.6 ohms
3. from the bottom to the top left is 3.6 ohms
THREE QUESTIONS:
1. Are the coils in the Compressor OK?
2. What symptoms "could be" present if the capacitor was bad?
2. What symptoms would be present if it was out of Freon?
Thank you for your patience and time. You advice is deeply appreciated!
Ads By Google
Related Models
Kenmore 106.56075791  REFRIGERATOR
Kenmore 106.5721160  COLDSPOT FREEZER
Kenmore 106.5721200  COLDSPOT FREEZER
Kenmore 106.5721201  COLDSPOT FREEZER
Kenmore 106.5821160  COLDSPOT FREEZER
Kenmore 106.5821200  COLDSPOT FREEZER
Kenmore 106.5825120  COLDSPOT FREEZER
Kenmore 106.5825121  COLDSPOT FREEZER
Kenmore 106.5825160  COLDSPOT FREEZER
Kenmore 106.5825200  COLDSPOT FREEZER
Kenmore 106.5827120  COLDSPOT FREEZER
Kenmore 106.5829100  MIRA-COLD FREEZER
Kenmore 106.5923120  COLDSPOT FREEZERS
Kenmore 106.5923121  COLDSPOT FREEZERS
Kenmore 106.5923160  COLDSPOT FREEZERS
Kenmore 106.5923161  COLDSPOT FREEZERS
Kenmore 106.5923200  COLDSPOT FREEZERS
Kenmore 106.5923201  COLDSPOT FREEZERS
Kenmore 106.5927120  COLDSPOT FREEZERS
Kenmore 106.5927121  COLDSPOT FREEZERS
Kenmore 106.5927160  COLDSPOT FREEZER
Kenmore 106.5927161  COLDSPOT FREEZER
Kenmore 106.5927200  COLDSPOT FREEZERS
Kenmore 106.5927201  COLDSPOT FREEZERS
Kenmore 106.5928100  COLDSPOT FREEZER
Kenmore 106.5929100  COLDSPOT FREEZER
Kenmore 106.6021100  COLDSPOT FREEZER
Kenmore 106.6021101  COLDSPOT FREEZER
Kenmore 106.6023120  COLDSPOT FREEZER
Kenmore 106.6025120  COLDSPOT FREEZER
Kenmore 106.6025121  COLDSPOT FREEZER
Kenmore 106.6025150  COLDSPOT FREEZER
Kenmore 106.6025151  COLDSPOT FREEZER
Kenmore 106.6025160  COLDSPOT FREEZER
Kenmore 106.6025161  COLDSPOT FREEZER
Kenmore 106.6025200  COLDSPOT FREEZER
Kenmore 106.6025201  COLDSPOT FREEZER
Kenmore 106.6121100  COLDSPOT FREEZER
Kenmore 106.6123120  COLDSPOT FREEZER
Kenmore 106.6123170  COLDSPOT FREEZER
Kenmore 106.6123210  COLDSPOT FREEZER
Kenmore 106.6125160  COLDSPOT FREEZER
Kenmore 106.615120  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.6221100  COLDSPOT FREEZER
Kenmore 106.6221101  COLDSPOT FREEZER
Kenmore 106.6221102  COLDSPOT FREEZER
Kenmore 106.622150  COLDSPOT FREEZER
Kenmore 106.6222170  COLDSPOT FREEZER
Kenmore 106.6222171  COLDSPOT FREEZER
Kenmore 106.6222172  COLDSPOT FREEZER
Kenmore 106.6222173  COLDSPOT FREEZER
Kenmore 106.6223120  COLDSPOT FREEZER
Kenmore 106.6223170  COLDSPOT FREEZER
Kenmore 106.6223210  COLDSPOT FREEZER
Kenmore 106.6225120  COLDSPOT FREEZER
Kenmore 106.6225170  COLDSPOT FREEZER
Kenmore 106.6226130  COLDSPOT FREEZER
Kenmore 106.6226150  COLDSPOT FREEZER
Kenmore 106.6226151  COLDSPOT FREEZER
Kenmore 106.6226152  COLDSPOT FREEZER
Kenmore 106.6226153  COLDSPOT FREEZER
Kenmore 106.6226170  COLDSPOT FREEZER
Kenmore 106.6227130  COLDSPOT FREEZER
Kenmore 106.625120  COLDSPOT FREEZER-10.7 CUBIC FEET
Kenmore 106.625121  COLDSPOT FREEZER-10.7 CUBIC FEET
Kenmore 106.625140  COLDSPOT FREEZER-12.4 CUBIC FEET
Kenmore 106.625201  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625202  COLDSPOT VERTICAL FREEZER 15.7 CUBIC FEET
Kenmore 106.625210  COLDPOINT FREEZER-15.7 CUBIC FEET
Kenmore 106.625220  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625221  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625222  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625240  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.625242  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.625250  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.711060  COLDSPOT FREEZER-6.6 CUBIC FEET
Kenmore 106.712060  COLDSPOT FREEZER
Kenmore 106.712061  COLDSPOT FREEZER
Kenmore 106.720120  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720122  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720123  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720124  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.720140  COLDSPOT FREEZER 12.5 CUBIC FEET
Kenmore 106.720141  COLDSPOT FREEZER-12.5 CUBIC FEET
Kenmore 106.720200  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720210  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720211  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720220  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720221  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720240  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720241  COLDSPOT FREEZER-15.3 CUBIC FEET
Kenmore 106.720300  COLDSPOT FREEZER-15.3 CUBIC FEET
Kenmore 106.720420  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720421  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720440  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720441  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720442  COLDSPOT FREEZERS
Kenmore 106.720450  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720451  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720452  COLDSPOT FREEZERS
Kenmore 106.720460  COLDSPOT FREEZERS
Kenmore 106.720461  COLDSPOT FREEZERS 17.0 CUBIC FEET
Kenmore 106.720470  COLDSPOT FREEZERS
Kenmore 106.720471  COLDSPOT FREEZERS 17.0 CUBIC FEET
Kenmore 106.720480  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720481  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720490  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720491  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720550  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720551  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720552  COLDSPOT FREEZERS
Kenmore 106.720620  COLDSPOT FREEZER-21.0 CUBIC FEET
Kenmore 106.720640  COLDSPOT FREEZER-20.3 CUBIC FEET
Kenmore 106.720641  COLDSPOT FREEZER-20.3 CUBIC FEET
Kenmore 106.721040  COLDSPOT FREEZER 3.9 CUBIC FEET
Kenmore 106.721120  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.721121  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.721140  COLDSPOT FREEZER 12.5 CUBIC FEET
Kenmore 106.721200  COLDSPOT FREEZER 15.8 CUBIC FEET
Kenmore 106.721201  COLDSPOT FREEZER 15.8 CUBIC FEET
  #2 (permalink)
Old 09-19-2012, 12:51 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Here is the relay/overload Part number: W10197427
It should be similar to the old one. Capacitor plugs in.
Now to your questions.
Compressor windings seams OK, with bad cap the compressor will run, gets hot and cycle on the overload.
Without the freon the fridge will run non stop.
If you have the multimeter check the capacitor, but it's most likely good.
Check the compressor windings to the "ground".
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-19-2012, 02:38 PM
Junior Member
Default
Thank you. Makes a lot of sense. I will check.
  #4 (permalink)
Old 09-27-2012, 12:46 PM
Junior Member
Default
The compressor is not shorted to ground. Starter/overload relay?
  #5 (permalink)
Old 09-27-2012, 02:58 PM
Expert
Default
Hi.
Most likely what it is.
Simon.
__________________
  #6 (permalink)
Old 09-28-2012, 04:18 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
First off, compressor winding measurements will NOT show they are good, only indicates which windings are start and run, and shows they are not blown open.
The real problem may be a burnt wire someplace which lowers the voltage to the evaporator fan motor and compressor. The old start device is probably ok. I would check both compressor voltage and evaporator voltage to confirm low voltage.
__________________
  #7 (permalink)
Old 09-28-2012, 09:25 AM
Junior Member
Default
I know it is not the start/overload. We got a starter/overload/capacitor all in one from a local store you wire onto the compressor and it does the same thing.
When I disconnect and check the start voltage going to the compressor (not on the compressor but from the start source), I get 120v after a few seconds after we plug it in.
I unplugged the unit, reconnected the start wire to the compressor and it disappears and stays at millivolts rather than going to 120v before.
Seems to me to be a bad compressor. Too bad!
  #8 (permalink)
Old 09-28-2012, 10:27 AM
Expert
Default
Hi.
Check the wire harness to the compressor and if it's OK - you should try to replace the control board in the fresh food section Part number: 8201527
Possibly the compressor relay is bad, not holding the start amps.
You can return any parts back even installed ones.
Post the results.
Simon.
__________________
  #9 (permalink)
Old 09-28-2012, 01:38 PM
Senior Expert
APP Volunteer
Default
Re-check the winding resistance, it's possible you blew out the start winding.
Also, if you had low voltage to the compressor, your windings may be burnt, resistance checks would not detect that, only a monitor of the current would detect burnt windings.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer compressor not starting scotty562 Refrigerator & Freezer Repair 5 03-05-2012 11:06 AM
Compressor Starting Device Brustrok Refrigerator & Freezer Repair 0 01-25-2012 01:09 PM
Compressor not starting smokeyhall Refrigerator & Freezer Repair 2 12-05-2011 08:19 PM
Compressor not starting jeff2011 Refrigerator & Freezer Repair 1 03-16-2011 12:37 PM
GE Profile Refrigerator - Compressor not starting VFR750 Refrigerator & Freezer Repair 0 10-04-2010 07:35 PM
