roper refridgerator
have a roper fridge that wasnt cooling properly thought it was a deforst isssue so let it defrost over night. upon start up i heard the compressor start it cooled for about two hours then stop i tryed to get the compressor to start up again no luck. thinking it is stuck in defrost i replaced the timer apon start up the compresstor kicked in but it didn't cool now i don't hear the compressor kick in any more. could i be looking at the start relay?
HI.
If the evaporator fan running check for 1250VAC at the compressor. If the proper voltage is present check the compressor's pins for continuity between them and the ground. Compressor checks out fine - replace the relay/overload. Here are the breakdown diagrams and Replacement parts for Roper RT18DKXBW20 REFRIGERATOR | AppliancePartsPros.com Thank you. Post the results. Simon. |
Quote:
Hi.
If you are absolutely sure that the capacitor is rattling - replace it too. Simon. |
| All times are GMT -7. The time now is 02:45 PM. |
