Discuss
Haier Freezer Thermostat Replacement
 in
Refrigerator & Freezer Repair
I have a Haier chest freezer model BD120G. I found out the green power light was out and I replaced
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Haier Freezer Thermostat Replacement
  #1 (permalink)
Old 09-17-2012, 07:05 AM
Junior Member
Rick5472 is on a distinguished road
Default Haier Freezer Thermostat Replacement
Model Number: BD120G   Brand: -other-   Age: 5 - 10 years
I have a Haier chest freezer model BD120G. I found out the green power light was out and I replaced that but my freezer's compressor was running continuously because the "Quick Freeze" switch was on. After replacing the green power light I turned off the quick freeze switch and the unit never came back on. I believe that the thermostat is bad because the unit works in quick freeze mode I guess it bypasses the thermostat.
My problem is how to replace the thermostat. I cannot figure out how to get the plastic mounting plate off without breaking it. I can see the thermostat and internal works from the access panel on the right side. I appreciate any suggestions.
Ads By Google
Related Models
Amana BD16E Ref - Bottom Mounts
Amana BD16LE Ref - Bottom Mounts
Magic Chef BDB420-1 Dishwasher - Undercounter
Magic Chef BDC420-1 Dishwasher - Undercounter
Magic Chef BDC520-1 Dishwasher - Undercounter
Magic Chef BDC620-1 Dishwasher - Undercounter
Magic Chef BDC720-1 Dishwasher - Undercounter
Magic Chef BDD520-1 Dishwasher - Undercounter
Magic Chef BDD620-1 Dishwasher - Undercounter
Magic Chef BDD720-1 Dishwasher - Undercounter
Maytag BDE110 Dryer - Ele
Maytag BDE210 Dryer - Ele
Maytag BDE212 Dryer - Ele
Maytag BDE303 Dryer - Ele
Maytag BDE312 Dryer - Ele
Maytag BDE313 Dryer - Ele
Maytag BDE4000 Dryer - Ele
Maytag BDE410 Dryer - Ele
Maytag BDE412 Dryer - Ele
Maytag BDE482 Dryer - Ele
Maytag BDE490 Dryer - Ele
Maytag BDE4910 Dryer - Ele
Maytag BDE510 Dryer - Ele
Maytag BDE512 Dryer - Ele
Maytag BDE590 Dryer - Ele
Maytag BDE5910 Dryer - Ele
Maytag BDE610 Dryer - Ele
Maytag BDE612 Dryer - Ele
Maytag BDE710 Dryer - Ele
Maytag BDE712 Dryer - Ele
Maytag BDE713 Dryer - Ele
Maytag BDE7400 Dryer - Ele
Maytag BDE7500 Dryer - Ele
Maytag BDE7600 Dryer - Ele
Maytag BDE7800 Dryer - Ele
Maytag BDE8000 Dryer - Ele
Maytag BDE8200 Dryer - Ele
Maytag BDE8300 Dryer - Ele
Maytag BDE8410 Dryer - Ele
Maytag BDE8420 Dryer - Ele
Maytag BDE8500 Dryer - Ele
Maytag BDE8600 Dryer - Ele
Maytag BDE882 Dryer - Ele
Maytag BDE9700 Dryer - Ele
Maytag BDE9800 Dryer - Ele
Maytag BDE9900 Dryer - Ele
Maytag BDG110 Dryer - Gas
Maytag BDG210 Dryer - Gas
Maytag BDG212 Dryer - Gas
Maytag BDG303 Dryer - Gas
Maytag BDG312 Dryer - Gas
Maytag BDG313 Dryer - Gas
Maytag BDG4000 Dryer - Gas
Maytag BDG410 Dryer - Gas
Maytag BDG412 Dryer - Gas
Maytag BDG482 Dryer - Gas
Maytag BDG490 Dryer - Gas
Maytag BDG4910 Dryer - Gas
Maytag BDG510 Dryer - Gas
Maytag BDG512 Dryer - Gas
Maytag BDG590 Dryer - Gas
Maytag BDG5910 Dryer - Gas
Maytag BDG610 Dryer - Gas
Maytag BDG612 Dryer - Gas
Maytag BDG710 Dryer - Gas
Maytag BDG712 Dryer - Gas
Maytag BDG713 Dryer - Gas
Maytag BDG7400 Dryer - Gas
Maytag BDG7500 Dryer - Gas
Maytag BDG7600 Dryer - Gas
Maytag BDG7800 Dryer - Gas
Maytag BDG8000 Dryer - Gas
Maytag BDG810 Dryer - Gas
Maytag BDG8200 Dryer - Gas
Maytag BDG8300 Dryer - Gas
Maytag BDG8420 Dryer - Gas
Maytag BDG8500 Dryer - Gas
Maytag BDG8600 Dryer - Gas
Maytag BDG882 Dryer - Gas
Maytag BDG9700 Dryer - Gas
Maytag BDG9800 Dryer - Gas
Maytag BDG9900 Dryer - Gas
Amana BDI16E Ref - Bottom Mounts
Amana BDI16LE Ref - Bottom Mounts
Maytag BDNS24A9-RA  Ref - SXS/I&W
Maytag BDNS24A9R  Ref - SXS/I&W
Maytag BDNS24A9RA  Ref - SXS/I&W
Maytag BDNS24A9RH  Ref - SXS/I&W
Maytag BDNS24F9  30" Electric Built - in Tap Touch Cooktop
Maytag BDNS24F9-A  Ref - SXS/I&W
Maytag BDNS24F9A  Ref - SXS/I&W
Maytag BDNS24F9H  Ref - SXS/I&W
Maytag BDNS24J9  Ref - SXS/I&W
Maytag BDNS24J9A  Ref - SXS/I&W
Maytag BDNS24L9  Ref - SXS/I&W
Maytag BDNS24L9A  Ref - SXS/I&W
Maytag BDNS24L9K  Ref - SXS/I&W
Maytag BDNS24L9KA  Ref - SXS/I&W
International BDNS24M92 Ref - SXS/I&W
International BDNS24M9K2 Ref - SXS/I&W
Maytag BDNT22C9  Ref - Top Mount/ I&W
Maytag BDNT22C9A  Ref - Top Mount/ I&W
Maytag BDNT22C9H  Ref - Top Mount/ I&W
Maytag BDNT22E9  Ref - Top Mount/ I&W
Maytag BDNT22E9A  Ref - Top Mount/ I&W
Maytag BDNT22E9H  Ref - Top Mount/ I&W
Maytag BDNT22F9  Ref - Top Mount/ I&W
Maytag BDNT22F9-A  Ref - Top Mount/ I&W
Maytag BDNT22F9A  Ref - Top Mount/ I&W
Maytag BDNT22F9H  Ref - Top Mount/ I&W
Maytag BDNT22H9  Ref - Top Mount/ I&W
Maytag BDNT22H9A  Ref - Top Mount/ I&W
Maytag BDNT22H9H  Ref - Top Mount/ I&W
Maytag BDNT22J9  Ref - Top Mount/ I&W
Maytag BDNT22J9A  Ref - Top Mount/ I&W
Maytag BDNT22J9L  Ref - Top Mount/ I&W
Maytag BDNT22J9LA  Ref - Top Mount/ I&W
Maytag BDNT22K9  Ref - Top Mount/ I&W
Maytag BDNT22K9A  Ref - Top Mount/ I&W
Maytag BDNT22K9L  Ref - Top Mount/ I&W
  #2 (permalink)
Old Yesterday, 11:48 AM
Junior Member
beckyandjohn is on a distinguished road
Red face
My experience is that the cover plate is held in place by four internal plastic clips; you WILL break at least two, in order to remove the plate...use a clear cement to re-attach.
You may have a second problem: the thermostat probe must be removed from a tube in the freezer...and the probe is cemented in place! Applying pressure to the tube doesn't work, and if you break the tube, goodbye freezer.
Haier tech told me to pull on the tube...didn't work. Asked how to bypass the cement problem and had no more communication from the tech.
A related problem: if you want to replace a worn gasket, you must buy the entire door from Haier...they don't sell just the gasket!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Haier chest freezer too cold! biorob Refrigerator & Freezer Repair 2 09-15-2011 07:14 PM
Thermostat replacement jasonpmcconnell Microwave Repair 0 08-16-2011 12:47 PM
Thermostat Replacement jerryallen Oven Repair (including Ranges and Cooktops) 1 05-16-2009 08:43 AM
thermostat replacement Lisa g Oven Repair (including Ranges and Cooktops) 0 11-06-2008 08:37 AM
new thermostat replacement deronsherry Oven Repair (including Ranges and Cooktops) 0 10-05-2007 06:41 AM
