| » Ice Maker not working |
Model Number: ksrg25ftst01 Brand: Kitchen Aid Age: 1 - 5 years
First the ice quit dispensing, I think I have figured out the problem to that as the drive shaft for the auger looks stripped. I am going to order that part. But now the ice maker quit making ice. The front water dispenser is working and from what I can tell the water supply to the ice maker isn't clogged. When I push in the lever on the left for the infrared the red light is solid and when I let it out the red light blinks twice. What should I check next? Thanks
Hi.
To check if this is the icemaker or the water valve switch around the solenoid plugs at the water valve and push the water dispenser lever. If the icemaker starts filling up - then it's a bad icemaker. The water valve Part number: W10408179 The icemaker Part number: 2198597 Here are the breakdown diagrams and Replacement parts for Whirlpool KSRG25FTST01 REFRIGERATOR | AppliancePartsPros.com Post the results. Si9mon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Have you looked at the water valve? There are 2 solenoids with the disconnect plugs. Switch this plugs around.
The water lever is what you press to start the water in the dispenser. Simon.
__________________
Ok Simon, I did switch the leads on the water valve and when I push the water lever the ice maker does fill up. So is there anything else I need to check? Or is it 100% the icemaker before I go ahead and order an icemaker?
Hi.
Sorry couldn't get back earlier. You should go ahead and replace the icemaker. Post the results. Simon.
__________________
| Display Modes | |
| Ice Maker not working, water dispenser is working fine | Monique | Refrigerator & Freezer Repair | 43 | 08-21-2012 09:18 PM |
| water dispenser not working ice maker working | jenniewolfram | Refrigerator & Freezer Repair | 1 | 03-04-2011 08:58 AM |
| compressor fan not working/ice maker not working | frisbeeman | Refrigerator & Freezer Repair | 1 | 12-15-2010 03:17 PM |
| Water dispenser not working ice maker is working | whmstang99 | Refrigerator & Freezer Repair | 0 | 08-29-2010 09:29 AM |
| ice maker not working. replaced ice maker. still not working. | inge | Refrigerator & Freezer Repair | 0 | 06-23-2008 09:59 AM |
