Quote:
Originally Posted by Jagsmaned
Hello,
If it is just the sides of the unit that are hot to touch then it would not be a defrost issue with the defrost heater. The defrost heater is on the inside of the unit behind the back wall of freezer under evaporator coils. There could be several reasons for the cabinet walls to be overly hot. Atmospheric conditions could be one factor such as the unit being located in a garage or shed where the temperatures get above 95 degrees. This causes unit to not be able to release heat into atmosphere. The outer part of cabinet acts as a condenser and has to be able to release heat into atmosphere.
Both outside metal
sides are hot, when I turn off the freezer the walls become cool, it appears that the defrost elements are in each side, Every time I unplug and allow to sit 10 minutes the side metal feels cool, then 5 minutes after turning back on both metal sides, (outside wall) become very warm, this may sound weird but it appears the out side metal sides has warped due to the heat, the metal is convoluted!
