Refridgerator/freezer light works but does not cool. Replaced run capicator & overload relay with new ones. With the new run run capacitor & run relay installed, I can hear the relay click, the compressor seems to hum, then after a few minutes, another click. Also, the condenser fan runs. No cooling in the fridge compartments. I took a continuity reading from each terminal pin to the housing of the compressor - no reading so the compressor is not shorted to ground. I took resistance readings on the three compressor pins. Resistance readings were as follows: Top pin to Bottom Left pin - 5.0 ohms; Top pin to Bottom Right pin - 5.3 ohms: Bottom Left pin to Bottom Right pin - 7.8 0hms. What else can I check to determine the problem? Do you think that the new run capacitor is bad? I have no way to check it.
Appreciate any advice - thanks.
Sounds like the compressor has gone bad.
