Discuss
Kenmore Cold Spot
 in
Refrigerator & Freezer Repair
I have a Kenmore Cold Spot side-by-side with water dispenser and ice maker. The ice dispenser and ice maker no
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Cold Spot
  #1 (permalink)
Old 01-29-2008, 07:51 PM
Junior Member
jmac357 is on a distinguished road
Red face Kenmore Cold Spot
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Cold Spot side-by-side with water dispenser and ice maker. The ice dispenser and ice maker no longer works. I checked the back of the fridge and made sure the water was turned on and it was. But the part that the water hose is plugged in to was not sending water into the fridge or the ice maker. I took the part (part#2182106) off and am going to replace it. Has anyone else had this problem just in case this is not the problem?
Ads By Google
  #2 (permalink)
Old 01-30-2008, 07:36 AM
Member
RegUS_PatOff is on a distinguished road
Default
It could be bad, did you check either the resistance or voltage ?
are any of the lines frozen ?
  #3 (permalink)
Old 02-01-2008, 06:59 PM
Junior Member
Default
No I just went out and purchased a new valve hoping that is the problem. Do you think it could be something electrical? God, I hope not...I hope by me replacing the part my problems will be resolved
  #4 (permalink)
Old 02-02-2008, 04:47 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Just don't install the valve, stick 115 volts to the old valve and check water flow at the output of the valve. If ok, you can return the unused valve.
You may have a frozen water line, or bad water flow to the valve.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how old is the kenmore cold spot 106? bobbyd2 Refrigerator & Freezer Repair 5 08-04-2011 06:09 AM
Cold Spot Upright Freezer b.vanderroest Refrigerator & Freezer Repair 1 06-08-2009 09:51 AM
Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough tvGhouse Refrigerator & Freezer Repair 0 02-25-2009 02:50 PM
kenmore cold spot cangrejo7 Refrigerator & Freezer Repair 1 01-06-2009 08:39 PM
Brown spot on clothes lvitale Dryer Repair 3 03-15-2008 11:41 AM
