Discuss
Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem
 in
Refrigerator & Freezer Repair
The water filter needed replaced as the red light came on. Around the same time I notice that the water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem
  #1 (permalink)
Old 09-05-2012, 11:14 PM
Junior Member
uswdyp47 is on a distinguished road
Question Water dispenser--low pressure. Ice maker--hollow ice cubes and dispenser problem
Model Number: 2652kew   Brand: Maytag   Age: 1 - 5 years
I notice that the water dispenser had lost a lot of pressure. It takes 5 minutes to fill a cup where as it was taking less than 10 seconds to do so. We replaced the water filter. Green light is on. However the water pressure is still very low. Everything has been working fine for the past few years (since we purchased). Need help figuring out which part to replace. In addition our ice maker is making hollow ice cubes. We noticed this around the same time as the water pressure being low in dispenser. We have not had any leaks or other issues. I don't know if the water intake valve is bad or if it might be the filter housing or something else. On another note, the ice dispenser will dispense cubes but it will stop dispensing after a couple seconds and makes a loud grinding noise. Please help. Thanks.
Ads By Google
Related Models
Maytag 2699A Refrigerator/freezer
Maytag 2699W Refrigerator/freezer
Jenn-Air 2700EEL Walloven - Std Ele
Hoover 2720
Hoover 2726 Kelvinator/range
Whirlpool 2733W0A
Whirlpool 2733^0A
Whirlpool 2735W0A
Whirlpool 2735^0A
Jenn-Air 2750ELS Walloven - Std Ele
Whirlpool 2763W0A
Whirlpool 2763^0A
Whirlpool 2765W0A
Whirlpool 2765^0A
Jenn-Air 2770ELD Walloven - Std Ele
Jenn-Air 2775ELD Walloven - Std Ele
Kenmore 278.3018890  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3018891  GAS BUILT-IN OVEN
Kenmore 278.3118890  KENMORE 30 IN GAS BUILT-IN OVEN
Kenmore 278.3118891  GAS BUILT-IN OVEN
Kenmore 278.3128810  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3128811  GAS BUILT-IN OVEN
Kenmore 278.3128890  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3128891  GAS BUILT-IN OVEN
Kenmore 278.3138810  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138811  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138815  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138817  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138895  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138896  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3138897  EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 278.3218510  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3218590  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3218591  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3218890  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3228690  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248211  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248213  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248215  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248216  KENMORE GAS BUILT - IN OVEN
Kenmore 278.3248231  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248233  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248236  KENMORE GAS BUILT - IN OVEN
Kenmore 278.3248292  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248293  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248295  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3248296  KENMORE GAS BUILT - IN OVEN
Kenmore 278.3288690  KENMORE GAS BUILT-IN OVEN
Kenmore 278.3528610  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 278.3528810  DROP IN GAS RANGE
Kenmore 278.3528811  Range, Electric/Gas
Kenmore 278.3548690  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 278.3548810  KENMORE GAS RANGE
Kenmore 278.3548811  KENMORE GAS RANGE
Kenmore 278.3548812  DROP-IN GAS RANGE
Kenmore 278.4018810  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4018811  ELECTRIC BUILT-IN OVEN
Kenmore 278.4018812  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4018890  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4018891  ELECTRIC BUILT-IN OVEN
Kenmore 278.4018892  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4028890  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4028891  ELECTRIC BUILT-IN OVEN
Kenmore 278.4028892  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038814  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038890  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038891  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038892  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038893  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4038894  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4088813  ELEC. BUILT-IN OVEN
Kenmore 278.4088890  KENMORE 27 INCH ELECTRIC BUILT-IN OVEN
Kenmore 278.4088891  KENMORE 27 INCH ELECTRIC BUILT-IN OVEN
Kenmore 278.4088892  ELEC. BUILT-IN OVEN
Kenmore 278.4088893  ELEC. BUILT-IN OVEN
Kenmore 278.4088894  ELECTRIC BUILT-IN OVEN
Kenmore 278.4218411  KENMORE ELECTRIC BUILT-IN-OVEN
Kenmore 278.4218491  KENMORE ELECTRIC BUILT-IN-OVEN
Kenmore 278.4218510  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4218590  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4228491  KENMORE ELECTRIC BUILT-IN-OVEN
Kenmore 278.4228590  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4228591  ELECTRIC BUILT IN OVEN
Kenmore 278.4228690  ELECTRIC BUILT-IN OVEN KENMORE
Kenmore 278.4228890  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4228891  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4228892  ELECTRIC BUILT-IN OVEN
Kenmore 278.4238590  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238591  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238592  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238690  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238890  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238891  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238892  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238893  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4238894  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4268490  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4268491  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4268590  KENMORE ELECTRIC BUILT-IN OVEN
Kenmore 278.4528811  Range, Electric/Gas
Kenmore 278.4538811  Range, Electric/Gas
Kenmore 278.7808510  KENMORE 30 INCH GAS RANGE
Kenmore 278.7808511  KENMORE 30 INCH GAS RANGE
Hoover 2800
Hoover 2830
Hoover 2836
Whirlpool 2843W0A
Whirlpool 2848W00
Whirlpool 2848W10
Whirlpool 2848W20
Whirlpool 2848W30
Whirlpool 2848W40
Whirlpool 2848W50
Whirlpool 2848^00
Whirlpool 2848^10
Whirlpool 2848^20
Whirlpool 2848^30
Whirlpool 2848^40
Whirlpool 2848^50
Whirlpool 2872W0A
Last edited by uswdyp47 : 09-05-2012 at 11:19 PM. Reason: Correct model is Maytag MSD2652KEW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I'm stumped - ice works, but no dispenser water pressure bigntaller Refrigerator & Freezer Repair 0 03-19-2011 09:52 AM
Ice maker dispenser does not dispense ice cubes. bcnvc Refrigerator & Freezer Repair 7 05-29-2010 07:57 AM
Door dispenser Low water pressure bdressel@eps-inc.us Refrigerator & Freezer Repair 3 05-13-2010 09:02 PM
Ice maker dispenser does not dispense ice cubes. bcnvc Refrigerator & Freezer Repair 1 05-12-2010 06:59 AM
Ice-maker Has Hollow Cubes TIMMO Refrigerator & Freezer Repair 4 03-30-2009 06:49 PM
