Hi everyone. My GE fridge has a bottom freezer and it is making gurgling noises. I have read that it could be a blocked drain plug. How do I get to the drain plug? Do I need to pull the fridge out? (it is a built in and very very heavy). Is this something I can fix myself? I had a repairman come and look at it and he told me there is restriction in the system and it is going to cost about $1600 for an over haul but I didn't believe him so I googled the problem and looks like he was trying to rip me off. Any help will be appreciated.
Groups: APP Team
HI.
If there is no ice building up on the bottom of the freezer - the repairman may be right. If the sound doesn't effect the performance you may just ignore it.
Simon.
Thanks for your reply Simon. How would I know if there is an ice build up? Should I pull the panel off at the back of the freezer?
Groups: APP Team
Hi.
Look under the bottom drawer.
Simon.
