| » Whilpool Not cooling. Please Help! |
Model Number: et8chmxktq4 Brand: Whirlpool Age: 1 - 5 years
Hello All, First Thank you for all the help that has gotten me to this point. I have this Whilpool, 03 build year. At first the fridge would ground fault, took it apart and found that the fan in the freezer had a broken ground wire, put that back together and she fired right up. I did have frost on the the coils, then the starter relay bit the dust. Put a 3 in one unit on it and the compressor fired right up. So now both fans and compressor are running but im not getting ANY cooling. Checked the defrost timer, and everything else should be good to go. Whats my next step? Thank you in advance.
Whats my next step?
Time to take a step backwards. Remove the evaporator cover. Check the coils . If they are heavily frosted/iced over you have a defrost problem. If they only have frost on part of the coils you probably have a low freon problem. It is usually around where the freon enters the evap coils from the compressor. Since the compressor is running if you have no frost/cooling on the evaporator coils, my guess is that the compressor is toast. If the frost is fairly even but it is not cooling efficiently check/clean the condenser coils and check that the compressor fan is running. For low freon and blown compressor, it probably makes more sense to buy a new unit rather than put dollars into this one as both these problems are fairly expensive to repair.
__________________
it was, and before I could tell the person that, they had plugged in it already ( as soon as it came from transport) what damage could that have caused?
Backstory - Working Fridge was sold, now the purchaser claims it doesn't work. |
It can contaminate the lines running up to the evaporator etc.
Often just unplugging it and letting it sit for the 24 hours will correct the problem. But this is just an often as turning the unit on can contaminate the lines further up.
__________________
Is there any way to flush the lines, or is that at the point where you should just get a new fridge?
Probably time for a new unit. Emptying, flushing and then refilling the freon lines is not going to be cheap. I would try letting it sit for the 24 hours.
__________________
| Display Modes | |
| Kenmore Oasis / Whilpool | freedom1 | Washer Repair | 6 | 12-02-2011 01:05 PM |
| Whilpool Gas Range | jdamgajian | Oven Repair (including Ranges and Cooktops) | 0 | 01-02-2010 08:59 AM |
| Whilpool Washer | Jkruege | Washer Repair | 2 | 09-15-2009 05:48 PM |
| Whilpool washer leaks | jdkiah | Washer Repair | 1 | 05-30-2009 05:34 PM |
| Whilpool Gas dryer | cbjgrant | Dryer Repair | 4 | 10-28-2008 08:30 AM |
