Hey All, Does anyone know of a source to get those little nylon hinge bushings? I recently acquired a Sub Zero 315W wine fridge and the top hinge is missing the bushing, which make the door wobble/loose. It isn't a separate part, and comes with the hinge. Seems silly to spend $35 on a new hinge assembly just to get that little .99 cent plastic part. Thanks! Here is a pic of the bottom bushing. I assume they are the same. Planethill attached the following image(s):
