After recently replacing the water filter with part number UKF7003 I amexperiencing problems with water flow through the dispenser. I have installed 2 new replacement filters believingthe first one was faulty. Afterreplacement water flow through the dispenser is normal for a day or so and thenslows to a near drip. If I remove thefilter and put in place the filter plug that came with the machine the flow isnormal. Also when I remove what the filterit pops off indicating significant backpressure behind the filter. Any indication of what could cause this. I have never experienced this prior toinstallation of these UKF7003 filters but this is now the listed replacement forthe old UKF7003AXX filters. Hope this makessense look forward to a reply. Thanks
