Double side fridge
Nothing is working except light in fridge and freezer, led is on on Ice maker switch, and I can hear the water solenoid for 3 second when I plug in the fridge, that's it.
No cold, No compressor, no outside fan (back bottom) no inside fan, no temperature indicator, no led on ice/water dispenser board, even not the light on water dispenser, no reaction for any of the buttons.
Looks like everything which should work with 12V isn't working ( if we considere that the thermostat work in 12v and doesn't switch the relay for the 120v compressor) this is just my idea
I tried to replace main board WR55X10942 without result.
Tried to find a 120 to 12v transformer, can't find any one either on the fridge or in your part list
Thanks for thinking about it
