| » In door Ice maker |
Model Number: ED2KHAXVB00 Brand: Whirlpool Age: 1 - 5 years
ice maker makes ice and dumps it in the bin, but the door cube/crushed ice dispenser does NOT activate.
Hi.
If the ice door and ice dispenser are not activating when the lever is pressed the problem is broken off pin holding the micro switch or the switch itself. Using the flat screw driver pry off the bottom of the frame and work it up. Remove the bracket and check the pin holding the switch. Unfortunately the bracket is no longer available, see if you can fix it by gluing the post or the switch back. Give it your best shot. Here is the breakdown diagram and Dispenser front replacement parts for Whirlpool ED2KHAXVB00 REFRIGERATOR | AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| In door Ice maker | strikeking105A | Refrigerator & Freezer Repair | 1 | 08-27-2012 08:21 PM |
| Ice Maker - Water to door, none to ice maker | robwhite61 | Refrigerator & Freezer Repair | 0 | 12-03-2010 03:31 PM |
| Ice maker door | redoak6280 | Refrigerator & Freezer Repair | 0 | 06-19-2010 09:43 AM |
| Replacing trap door between ice maker and out side of fridge door | robertgazda | Refrigerator & Freezer Repair | 0 | 12-28-2009 09:12 AM |
| In-door ice maker died | nokaoi1 | Refrigerator & Freezer Repair | 0 | 10-22-2009 12:38 PM |
