designbo
#1 Posted : Monday, August 27, 2012 4:25:38 PM(UTC)
designbo
moved refrigerator from old office to house. During move the refrigerator was laid on it's side. Let sit for about a week and then started up. Freezer worked great, but refrigerator was not cooling. Pulled out from wall to inspect unit underneath. Unit was covered in dust and hair.. we purchased used several years ago, but anyway unit compressor quit running. Inspected further and condenser fan not running as it seems to be worn out. Compressor starts but shuts off after few seconds. Questions are as follows:
1. have tried to find manual on model number above with no luck.
2. Can not remove freezer fan housing to determine if fan is not running fast enough.... without no manual hot to get off????
3. Condenser fan model number is hard to find, and would I assume this to be the issue.
can not find anything on model number listed above..
any help would be helpful....
#2 Posted : Tuesday, August 28, 2012 1:36:28 AM(UTC)
Check the model #, also, if the compressor is very hot, put a portable fan to cool the condenser and compressor.
designbo
#3 Posted : Tuesday, August 28, 2012 4:45:58 AM(UTC)
designbo
Model is HMG 21146 Can not find anything on this model....
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
