I have a 20 year old whirlpool side by side refer that I love. It has a problem with the water dispenser which dispenses water in a trickle and the ice maker produces hollow ice cubes that have black speckson them. The specks are from the paint which has peeled off the ice maker tray. I stripped off all paint and painted it with an acrylic based paint for food safety reasons. It peeled off after one day in use. Do I even need to paint this tray? It is aluminum so I don't have to worry about rust right? The other thing is that this refer was never on a water filter. It uses softened water direct from house supply. I suspect a clogged valve somewhere that is denying water to both ice maker and water dispenser. Any ideas?
