evaproator fan gets a buildup of ice on mounting braket until finally it stops the fan. I open it up remove the ice and it works fine again. Could someone please tell me what might be the problem?
Originally Posted by: argar100 evaproator fan gets a buildup of ice on mounting braket until finally it stops the fan. I open it up remove the ice and it works fine again. Could someone please tell me what might be the problem? Argar, When you "open it up" is there a large or heavy build up of frost or ice on the back wall(evaporator cover) of the freezer compartment? It sounds like a defrost issue. You'll need to check the heater assembly Part number: AP4527302
for a "closed" circuit. Check the defrost thermostat, Part number: AP2150145
For a "closed" circuit below 40 dgrs,F. and an "open" circuit at room temperature. If all checks OK, and there are no loose wires or connections, then the issue would be in the control, Part number: AP4300940
Here's some information that should help you out : "Manual Defrost Activation Press and hold Freezer Temperature UP (WARMER) Key while pressing the fresh food temperature DOWN (COLDER) key 5 times within 6 seconds. Deactivation Press and hold Freezer Temperature UP (WARMER) Key while pressing the fresh food temperature DOWN (COLDER) key 5 times within 6 seconds. Function Initiates a defrost cycle. All other functions are disabled including alarm(s) enabling." Thanks and Good Luck,
