The trays are not completely filling with water, causing small ice cubes that go through the crusher, and water in leaking into bottom of freezer, and freezing.
Originally Posted by: Joyce10 ...water in leaking into bottom of freezer... Where is this water coming from? Gene.
Originally Posted by: Gene Where is this water coming from?
Gene. I'm assuming some of water supposed to go in trays is getting to bottom of freezer.
