The frig has a water/ice dispenser selected by a switch. When getting either water or ice in a drinking glass from the dispenser the shut off switch sticks at times and the water or ice will not shut off. It may be the switch can be lubricated or it may need replacing. Is it difficult to get at the switch? Also how can I be sure if I'm ordering the correct part if it needs replacing?
